Re: Oil weight, which to use!
[Re: superbeedave]
#944738
03/06/11 09:34 PM
03/06/11 09:34 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
I can get Brad Penn $50.00 a case which is 12 quarts, not too bad! Please help me with my dilemma! Thanks!
50 beans for 12 quarts ? ...
[Re: superbeedave]
#944746
03/07/11 04:57 AM
03/07/11 04:57 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
It will run 65 psi hot at highway speeds down to 40-45 at idle when hot. Runs 75-80 when first starting up when cold with the 15w40. So you think I should stay with 15w40? I have never tried 10w30 in it yet.
Well according to the trusty 1969 Plymouth Service Manual here, it's specifying 45-65 PSI operating pressure @ 1000 R.P.M. with a minimum pump pressure of 20 PSI @ 500 R.P.M.
But your oil pump could be doing excess by-passing with the 15W-40.
I'd still give the 10W-30 Brad Penn a try with NO aftermarket pour-and-pray motor oil additives.
CompSyn
[Re: CompSyn]
#944747
03/07/11 05:01 AM
03/07/11 05:01 AM
dOOc
Florida STAYcation
...... with NO aftermarket pour-and-pray motor oil additives.
THAT'S a good one .....
Give ole CS a ceegar !
[Re: dOOc]
#944748
03/07/11 05:27 AM
03/07/11 05:27 AM
CompSyn
Pacific NW USA
Thanks for the props Doc. You know as well as any if one does his/hers homework, there's no need to play backyard chemist and mix your own....
Of course sniffing fiberglass fumes all day has a weird way hindering one's better senses
That's a joke Doc
[Re: CompSyn]
#944749
03/07/11 12:36 PM
03/07/11 12:36 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Just an FYI for those that have not yet seen it: Summit Racing is now offering its own line of semi-synthetic, high zinc content, multi-viscosity oils. @ 4.95, the price is right! I just did an oil change yesterday in my 451, using the Summit 10w-40. Bottles say manufactured by I.L.C. in Brookfield Conneticut.
[Re: Pacnorthcuda]
#944750
03/07/11 03:59 PM
03/07/11 03:59 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
40-45 at hot idle is pretty high, nothing really wrong with that, but it is indicative of a motor that would probably do just fine on 10w30, and save a bit of HP running the pump.
Plus, it would be a real bummer to twist or break the intermediate shaft because of the excess torque required to spin the pump...
[Re: CompSyn]
#944751
03/07/11 04:10 PM
03/07/11 04:10 PM
dOOc
Florida STAYcation
That's a joke Doc
Hey HAY ...I truly MISS those polyester resin and gel-coat fumes ....IN THE MORNING !
DID you see that article in the Car Craft magazine tooooo ? ...
