Stainless-steel Trim Restoration? #944641
03/06/11 07:40 PM
03/06/11 07:40 PM
Martinsburg PA
Crist Offline OP
Crist  Offline OP
Martinsburg PA
I have stainless-steel drip-rail moldings I need restored. First, looking for a source. Second, are there different degrees of restoration? Meaning… I think I need the dents/etc., removed; Then buffed/polished slightly. Thoughts? Central PA here @ 16662 Thanks!
Re: Stainless-steel Trim Restoration? [Re: Crist] #944642
03/06/11 11:55 PM
03/06/11 11:55 PM
Red Lion, PA USA
scamper340 Offline
scamper340  Offline
Red Lion, PA USA
Call Librandi's in Middletown. I had them polish all my stainless trim last year. It was expensive, but will be worth it when the car is finished. They removed some small dings in a few trim pieces, so I'm sure they will be able to fix you up. Here's a link to their website, you can find their number there: Librandi's Plating But keep in mind, they are very busy and it might take them awhile. I wasn't in a rush, so it wasn't a big deal for me.
Re: Stainless-steel Trim Restoration? [Re: scamper340] #944643
03/07/11 01:04 AM
03/07/11 01:04 AM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
I got an EastWoods kit and did this Hudson in the att. , you can
get pretty good at straightening and polishing stainless with some practice. I had a lot of hours doing this car but there is alot of stainless on it.
Re: Stainless-steel Trim Restoration? [Re: stateline] #944644
03/08/11 08:11 PM
03/08/11 08:11 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
You need to contact FY1TA on the board. Very good trim work, reasonable prices. honest as they come.
Re: Stainless-steel Trim Restoration? [Re: Paul Jacobs] #944645
03/09/11 02:02 PM
03/09/11 02:02 PM
Martinsburg PA
Crist Offline OP
Crist  Offline OP
Martinsburg PA
Working on all your suggestions... Thanks!
