'67 to '68 B-Body 3 speed wiper motor? #943464
03/05/11 04:32 PM
03/05/11 04:32 PM
Indianapolis
Waveraider Offline OP
Indianapolis
I keep going down this road... I've acquired a '67 3 speed Wiper motor with linkage. Can someone tell me if all this will fit my '68 Satellite and do I need ago change the linkage? Once again, thank you in advance.
Re: '67 to '68 B-Body 3 speed wiper motor? [Re: Waveraider] #943465
03/05/11 06:00 PM
03/05/11 06:00 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
Your 68 sat should have a 2808767 3 speed wiper motor if it is an early 68. if its alate 68 then a 2889982 speed wiper motor. if the 67 wiper motor you have is a 2808767 then it should work,it would be a late 67 or early 68 (2808767)Whays the build date of your car? if your car is a late 68 then the 2889982. the 67 is called a verible speed
Re: '67 to '68 B-Body 3 speed wiper motor? [Re: 268RTs4ME] #943466
03/05/11 10:20 PM
03/05/11 10:20 PM
Indianapolis
Indianapolis
Thanks for the reply. My car is a very early '68. I think my build date is 9/07/67.
Re: '67 to '68 B-Body 3 speed wiper motor? [Re: Waveraider] #943467
03/05/11 11:54 PM
03/05/11 11:54 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
The only part of the linkage you need is the arm that bolts the motor.
