Re: What brand of 9" drag slicks do you guys prefer?
[Re: hemiparts]
#943353
03/05/11 09:59 PM
03/05/11 09:59 PM
M/T's have always worked well for us and we'll be using them on my new " stick" car.
mickey thompsons here too. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dOc …]
#943356
03/06/11 12:00 AM
03/06/11 12:00 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I always run the Phoenix slicks, although a 10.5" tread. But there was a thread on YB awhile back that was several pages long and there was an overwhelming number that said the Hoosiers worked better on their small tire cars. If I keep my Dart I will be trying Hoosiers this year. The Phoenix tires work but they seem to be double the weight of a M/T when I lifted them at the same time.
[Re: 340man4ever]
#943359
03/06/11 10:37 AM
03/06/11 10:37 AM
Posts: 5,895 Florida
Locomotion
I've been running the Hoosier 30"x9" lightweight drag slicks for years and have been very happy with them. Radial slicks are faster, but they are more sensitive to track conditions so they will slip/spin a bit easier if the track isn't in the best shape. I usually race at IHRA nationals and divisionals where prep tends to be better than average. Local track prep can vary from track to track. I've tried to set my car up to work as well as possible with the radial slicks. But bias ply tend to be more consistent under average conditions. I just don't like the idea of swapping bias to radial if I need to pick up some ET for heads-up runs, qualifying, etc. because a radial slick can also quicken reaction times a bit. So I stay with the radials for overall consistency and predictability. Radial slicks tend to like more air pressure than their bias ply counterparts. It also helps to run a wide rim to allow more pressure & stiffer sidewalls. This helps maintain a fuller footprint with the higher pressures, a stiffer sidewall for longer slick life and less distortion that can migrate into the contact area. I use a 10" rim with my 9" tires. I run 21 lbs in my particular combo but have heard of other Stockers running anywhere from 14 to 26+ lbs! Lots of variables there and you just have to experiment to see what your set-up likes. Hoosier drag tire specs
[Re: 340man4ever]
#943361
03/06/11 11:24 AM
03/06/11 11:24 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
With all conditions the same, my car with me in it weighing 3200 lbs, 29 / 9 rear tire, couldnt get down there with the M/T tires. Put a set of Hoosiers on it, same size and bias ply, no problems at all. Both set were new. We tried running the air pressure up and down on the M/Ts with no luck. They would even break loose half track on us. Hoosiers are the tire for us on this car. One of our other cars weighing in a few hundred pounds less with a wider tire does ok with the M/Ts tho. ![](/ubbthreads/images/graemlins/beer.gif)
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
