Page 4 of 4 1 2 3 4
Re: Milodon's new pump cover [Re: SCATPACK 1] #943201
01/21/12 04:27 AM
01/21/12 04:27 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Well I bought the 440 cover, its even worse. I cut the side of the cover to try and clearance it and its still too close. If milodon would have moved the fitting foreward 1/2" it would have worked. Now I am stuck with another part I wont use....
Re: Milodon's new pump cover [Re: astjp2] #943202
01/21/12 11:45 AM
01/21/12 11:45 AM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
Are those stock Hemi mounts? Maybe trying different mounts or using a plate would be a better aproach?
Re: Milodon's new pump cover [Re: dm69charger] #943203
01/21/12 01:01 PM
01/21/12 01:01 PM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
Or maybe try reversing the bolts. Go outside in with the bolts instead of inside out like they are now. Unless they are studs, then take them out and try cap head bolts.
Re: Milodon's new pump cover [Re: prochargedhemi] #943204
01/21/12 01:22 PM
01/21/12 01:22 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
man what ever happened to people actually having to work to get things to fit? Everyone thinks that you buy aftermarket parts and they just bolt on, YOUR WRONG. However the pump does work with stock hemi mounts. just get a little creative
I understand what you are saying, that non-stock doesn't always fit. However, when designing an aftermarket part, it should take stock tolerances into account. They should have a stock block with stock parts bolted to it for fitting. They should also have at least their own aftermarket parts handy for fitting.
They might as well sell you a chunk of billet if you gotta machine it to work, especially if they will not warranty the part if any mods are made to it.
Would you consider purchasing it if the pump extended into the block area or tilted the filter up where headers normally reside? It's just poor planning on the company's part that it modified the part to extend from stock space into a known tight area.
Re: Milodon's new pump cover [Re: RodStRace] #943205
01/21/12 02:40 PM
01/21/12 02:40 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I find that aftermarket parts are generally poorly engineered for fit. I bought a Wilwood pedal assembly that had course thread on the pedal side, and their pushrod that came with their master cylinder had fine thread, or vice-versa. One problem is trying to make things fit between manufacturers when you are mixing and matching. My machinist was complaining about BBC heads since every aftermarket head has different designs. Sometimes having lots of choices leads to fit issues that require mods to put it all together. You almost need a mill and a lathe to build a race car since nothing seems to fit well.
Floyd Lippencott IV
Re: Milodon's new pump cover [Re: mr_340] #943206
01/21/12 05:42 PM
01/21/12 05:42 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i have the old green gasket setup.
i had to cut the drivers side mount off the k frame
and use elephant ears on my 440.
i still use the passanger side mount with the ears though
Re: Milodon's new pump cover [Re: mr_340] #943207
01/21/12 06:32 PM
01/21/12 06:32 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
To make matters worse, if you modify the aftermarket part to make it fit, they will often void the warranty. They build a part which will fit nothing, and won't stand behind the part's fitment, or performance once you make their part work
This makes me think of my Hooker Super Comp headers for the BB Mopar in an A-body. The design has been out for 40 years. In 40 years Hooker hasn't bothered to fix the problem of one collector aimed towards the ground (for no good reason) and the lack of tire clearance even with 24" tires. Both issues can be easily fixed, but hey, they built their jigs 40 years ago. Why should they spend a dime to make our lives a bit easier??
Re: Milodon's new pump cover [Re: 65dragnet] #943208
01/21/12 09:52 PM
01/21/12 09:52 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Nice piece. It only took them 4 years and its twice the price as mine (made in the USA as well)
I have two of Muscle Motors covers and they are superb Thanks Mike !
I had a muscle motors cover and it worked great I think it is still on backorder.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Milodon's new pump cover [Re: Kam*Kuda] #943209
01/22/12 04:00 PM
01/22/12 04:00 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Here is how much I tried to clearance the cover, it will still work on a 440, but not the hemi mount....Tim
Re: Milodon's new pump cover [Re: astjp2] #943210
03/17/12 05:08 PM
03/17/12 05:08 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Well I got my external oiling done, it only took a week once I found someone willing to bend a line. Here are some pics of a world block, stock mount, stock K-member and the new milodon 31581 road race oil pan. I primed the pump and got 75 PSI with an internally modified M63HV pump. It was expensive but I will never have to worry about the headers melting any form of hose. Tim
Re: Milodon's new pump cover [Re: astjp2] #943211
03/17/12 05:09 PM
03/17/12 05:09 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Pic 2
Re: Milodon's new pump cover [Re: astjp2] #943212
03/17/12 05:09 PM
03/17/12 05:09 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Pic 3
Re: Milodon's new pump cover [Re: astjp2] #943213
03/17/12 05:11 PM
03/17/12 05:11 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Pic 4
Re: Milodon's new pump cover [Re: astjp2] #943214
03/17/12 05:12 PM
03/17/12 05:12 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Pic 5
Re: Milodon's new pump cover [Re: astjp2] #943215
03/17/12 07:51 PM
03/17/12 07:51 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I hate to be a gloom and doom guy but PLEASE do a little more research before running that oil line set-up. After I rolled my Daytona on its roof at Norwalk in 2010 I was told by no less than 8 people that you should NEVER run a solid steel or aluminum line without some sort of flex in the line. Looking back at the Milidon system they are built with solid bent lines and then connected to flex lines where they connect to the pump. My solid line broke at the farrel from engine harmonics dumping oil on my tires leading to my wreck. My car passed tech at lots of tracks before this happened and I never gave it a thought until after my wreck when others pointed out my plumbing mistake. I hope this saves you or someone else from wrecking their car.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Milodon's new pump cover [Re: pittsburghracer] #943216
03/17/12 08:55 PM
03/17/12 08:55 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Well as an aircraft mechanic, there was an Airworthiness Directive that required hoses to be removed from horizontally opposed recriprocrating engine and be replaced with solid lines. I have done a lot research and determined that the line was too close to the headers to be safe with a hose. That tube is .049 ducticle steel. with the amount of bends the line should flex some and still not crack. Tim
Re: Milodon's new pump cover [Re: astjp2] #943217
03/17/12 09:15 PM
03/17/12 09:15 PM
PA.
"Little"John
"Little"John
PA.
That's what I thought and was quite proud of my work. I was a Millwright for 33 years and usually bent tubing every week. I hope it works out for you and it does look very nice. I only wish someone would have said something BEFORE I put my car on its roof. I will make no further comments on your thread so it doesn't get mucked up.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Milodon's new pump cover [Re: pittsburghracer] #943218
03/17/12 09:24 PM
03/17/12 09:24 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
How did you route your line?
Page 4 of 4 1 2 3 4
