Certainly could be. I recently learned that all V8 spool mounts are NOT the same. Check with a NAPA store for the mounts. They may even be able to produce a picture, or what the heck, log on to Rock autos site. You should be able to see the difference.
Not to top your story, But awhile back I was searching for a spare V8 k frame for my stable of A body projects when I spotted a 74 Dart with a V8 at a pick n pull yard. The motor sat sorta cocked to one side. Upon closer inspection it was sitting in a slant K frame with wierdly cobbled mounts held in with ONE bolt on each side!
