Page 1 of 4 1 2 3 4
Cruise Control on a '70 Challenger #941342
03/02/11 04:43 PM
03/02/11 04:43 PM
NJ, USA
Flying Banana Offline OP
NJ, USA
My '70 Challenger R/T w/auto in the console is coded for cruise control, but the steering column was replaced at some time in the past and the wiring and control stick are long gone. Is the stick a standard part across mopars, or specific to my car? If specific, is anyone reproducing this?
Re: Cruise Control on a '70 Challenger [Re: Flying Banana] #941343
03/02/11 04:57 PM
03/02/11 04:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
70-71 E-body only,,,,, and I'm not sure but it might also be 71-72 B-body as well
One of , if not the hardest cruise switches there is to find
Re: Cruise Control on a '70 Challenger [Re: gtx6970] #941344
03/02/11 05:16 PM
03/02/11 05:16 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i have factory cruise on my 70 cuda if remember right b body stick is at a differnt angle far as i know not reproduced good luck finding one ralph
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Cruise Control on a '70 Challenger [Re: Flying Banana] #941345
03/02/11 05:51 PM
03/02/11 05:51 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
As mentioned the E and B Body turn signal stalks with cruise look the same at first glance but are actually slightly different. They are not easy to find but do seem to pop up on ebay every now and again. If I'm not mistaken the wiring harness itself can be scavenged off of practically any car with factory cruise all the way through probably at least the mid 70's.
Re: Cruise Control on a '70 Challenger [Re: toplescuda] #941346
03/02/11 06:27 PM
03/02/11 06:27 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
1970-71 E body only speed control handle is longer than B body. It also has a sharper angle to compensate for the E body crush can that puts the steering wheel so far away from the turn signal switch.
Re: Cruise Control on a '70 Challenger [Re: twodoorpost] #941347
03/02/11 07:23 PM
03/02/11 07:23 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Below is B body. I had a 70RR with cruise, so collected several of these sticks when you could still find them - long gone on ebay. As noted the E stick has more angle. The head, switch, and lettering is the same for all. The C body has a screw in end. They are all rare.
Re: Cruise Control on a '70 Challenger [Re: 70runner] #941348
03/03/11 12:13 AM
03/03/11 12:13 AM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
C-Body Lever
Re: Cruise Control on a '70 Challenger [Re: EV2RTSE] #941349
03/03/11 12:15 AM
03/03/11 12:15 AM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
E Body lever, wiring harness, and brake switch
Re: Cruise Control on a '70 Challenger [Re: twodoorpost] #941350
03/03/11 12:42 AM
03/03/11 12:42 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And because you can't find an original one & also because the E body ones aren't chromed like all the others.. What I've done in the past is take two easily found switches, strip the electrical out of both of them, cut one near the area where the switch fits, cut the other the proper length to equal a real E body lever then weld the two pieces together... Laying them in V blocks will keep them straight, tack around the tube like doing body work, then grind it smooth... chucking it in a drill press makes getting the whole lever sanded for paint a breeze, clamp the area where it bolts to the T/S switch in a vise, heat the area just past the vise with a torch & adjust the lever angle... Prime, paint & reinstall the electrical & you now have a switch that no one will question...
Re: Cruise Control on a '70 Challenger [Re: 1_WILD_RT] #941351
03/03/11 01:04 AM
03/03/11 01:04 AM
NJ, USA
NJ, USA
If it isn't chromed, what paint color is it? And are the electronics basically standard across models? If I fab up the stick as you suggest, is there a best model to look for the donor parts?
Re: Cruise Control on a '70 Challenger [Re: Flying Banana] #941352
03/03/11 01:20 AM
03/03/11 01:20 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The lever is silver argent.. You need a upper section from a 69-73 vehicle so it will have the style of switch shown it the above photos.. C body ones (the screw in style) are easiest to find & will work... For the lower section you need one of the type that was mounted with a screw like a standard lever.. The switch style doesn't matter so the later B body or FMJ body make good donors...
Re: Cruise Control on a '70 Challenger [Re: EV2RTSE] #941353
03/03/11 02:01 AM
03/03/11 02:01 AM
70runner Offline
70runner  Offline
C-Body Lever
I sold this one in April 2007
Re: Cruise Control on a '70 Challenger [Re: 70runner] #941354
03/03/11 02:15 AM
03/03/11 02:15 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
C-Body Lever
Got anymore, I think somebody needs one...
Re: Cruise Control on a '70 Challenger [Re: 1_WILD_RT] #941355
03/03/11 05:24 AM
03/03/11 05:24 AM
70runner Offline
70runner  Offline
Wish I did. I had collected about a dozen or so, but sold them all on ebag.
Re: Cruise Control on a '70 Challenger [Re: 70runner] #941356
03/03/11 09:52 AM
03/03/11 09:52 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
As stated above 68-69 B-body is similar to E-body but has a shorter handle.
Both have small black button on end.
Re: Cruise Control on a '70 Challenger [Re: mccannix] #941357
03/03/11 10:25 AM
03/03/11 10:25 AM
cataclysm80 Offline
cataclysm80  Offline
Thanks Mccannix! So if the 68-69 has the small button as you pictured, then the B body lever pictured above must be the 70-72 or 73 lever?
Tav
Re: Cruise Control on a '70 Challenger [Re: EV2RTSE] #941358
03/03/11 10:52 AM
03/03/11 10:52 AM
cataclysm80 Offline
cataclysm80  Offline
This is my setup. I'm using the lever, and possibly the brake switch. I sent that 70 e body wiring harness to M&H electric and had them build me a brand new one. Now that they have a diagram of how to make it, you should be able to call them and order one for yourself. M&H makes good stuff. They supply all of Year One's wiring harnesses. Due to limited parts availability (grommet) you won't find this harness in the Year One catalog. Call M&H direct to get it.
For the brake switch, they didn't change much up to the early 80's I think. Part # changed, but only difference I could find was the color of the wire.
I agree that the E body switch is different from the B body. I do have a B body switch installed in my 'Cuda and it works fine.
Tav
Re: Cruise Control on a '70 Challenger [Re: cataclysm80] #941359
03/03/11 11:05 AM
03/03/11 11:05 AM
cataclysm80 Offline
cataclysm80  Offline
E body
Tav
Re: Cruise Control on a '70 Challenger [Re: cataclysm80] #941360
03/03/11 11:08 AM
03/03/11 11:08 AM
cataclysm80 Offline
cataclysm80  Offline
B body
with these pics you can see the differences a little better. There is a slight angle difference, and the E body lever is about 1.5 inches longer. Also, the B body is chromed, while the E body appears more matte.
Tav
Re: Cruise Control on a '70 Challenger [Re: 1_WILD_RT] #941361
03/03/11 11:22 AM
03/03/11 11:22 AM
cataclysm80 Offline
cataclysm80  Offline
I might try that sometime Randy.
Here is an exploded view of a B body lever (also typical of E body).
Dissassembly not for the weak of heart. The chrome ring that you rotate for acceleration is Fragile, and the black plastic is Not meant to come off of the metal stalk.
This is the one I'm currently using on my 'Cuda.
Tav
Page 1 of 4 1 2 3 4
