5.7 hemi having trouble starting #940834
03/01/11 08:52 PM
03/01/11 08:52 PM
Memphis, MO
X
xpsyclonex2002 Offline OP
X
Memphis, MO
I swapped a 5.7 into my 66 coronet. I can get it to start with starting fluid and run for about 1 minute (idles roughly). Then it shuts down. It won't start without the starting fluid. It turns over and I have checked the fuel pressure and appear to have well over 50 psi. any advise?
Re: 5.7 hemi having trouble starting [Re: xpsyclonex2002] #940835
03/01/11 09:17 PM
03/01/11 09:17 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
did you do anything with timing chain, by chance?
