Re: edelbrock 2177 cam good for stock 360 with rpm 4bbl?
[Re: moturbopar]
#940627
03/01/11 04:52 PM
03/01/11 04:52 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
comp XE250/XE256 or a lunati voodoo 60400/60401 would suit you better. use comp #901 springs, and ditch the exhaust valve rotators if you have them
[Re: 602heavy]
#940629
03/01/11 08:29 PM
03/01/11 08:29 PM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
Factory cam IIRC is .410 lift, 252 (gross) duration, so yes you're new cam is more agressive but with only 204 duration you won't notice a ton of improvement.
I'd look at the old Engle (Hughes proprietary grind) single pattern which was ~223 @.050 and IIRC around .504 lift on 110 centers, you'll know it's there for sure but it's not radical at all. Engle might still sell it if you refer to the old Hughes .904 grind. Another good slightly milder one (if you can find one) is the old Cam Dynamics 266 which was 216 @.050 and .467 lift on 112 in at 107. 360's don't mind a bit bigger cam but don't go over about 224 @.050, the cams I mentioned here will be about the same off idle as stock power wise but choppier, and you'll definately feel the extra torque through the middle in the passing gear and when you wind it out.
[Re: Streetwize]
#940630
03/02/11 10:10 AM
03/02/11 10:10 AM
patrick
Grand Haven, MI
IIRC the stock cam is somewhere between 180-190 degrees@.050" lift I gotta disagree with 'wize a bit, I think his recommendations are still too big for a 3/4 ton truck that I would guess is in the 4500-5000lb range. the XE262 worked real well in the stock long block 360 that I home ported the 1.88 heads and ran with an eddie 600, RPM air gap, and headers in my 3950 lb 5th avenue. but I also ran 3.55's with 27" tall tires, a low gear 904, and a MP166K converter, which brake stalled to ~2300 RPM and flashed to about 2700. I wouldn't use any less stall than this with this combo.... if you wanted to go up to something in the [Email]218-224@.050[/Email] range, I'd definitely upgrade to KB107 pistons, or stock pistons and magnum heads. even with the smaller cams I mentioned, the magnum heads would probably be worth another 15-20 HP/tq over standard 360 heads.
[Re: patrick]
#940631
03/02/11 11:15 AM
03/02/11 11:15 AM
Streetwize
Weddington, N.C.
The Cam dynamics 266 is a real pussycat cam and that hughes made tremendous upper bottom torque both in stock short block 360's with no downside drivability issues at all, just quickening the ignition curve more than made up for the longer duration. If you calc out the intake closing with the 223 event and a 106 ICL you'll find you still have more effective displacement than EX: a 318 with a stock cam, I plowed 3 feet of snow with a stock 318 4x4. The longer 360 stroke and the small 1.88 valve (from my experience) wants a bit more cam, it's a bit like the old super duty 455, it wants more cam than you think it does and the payoff at 3000+ and the extra seat to seat doesn't noticably reduce the off-idle drivability. I'd compare the hughes idle/low end manners to the 340 factory magnum cam, which IIRC was alsos the same cam they put in the 360 little red express. Not to take issue, but by the same token some of the smaller Comp XE grinds I've been experienced with and "fixed" had some detonation issues in hot weather down here in the Carolinas, I'm a little leary of short seat to seat but longer @ .200 hydraulics, especially in port limited motors. I'd be more concerned about that in a heavier car/truck than I would with a bit slower ramp that is longer at .050. opinions vary though Seeing our friend is in the Netherlands and he may have thae cam in hand, I'd advise him to try out the Edelbrock (which is likely a repackaged SSI/General Kinetics cam IIRC), you could do a lot worse. If not, call Tim Goolsby at Bullet cams and have him spec you something....but my guess it'll be something in the 216-223 @.050 range But if your goal is ultimate stump pulling low end, and not stronger upper bottom through the mid range (220-4800) is your objective, here's a recipie from the Moparts tech archive. http://www.moparts.org/Tech/Archive/smallblock/8.html
[Re: Streetwize]
#940632
03/02/11 06:05 PM
03/02/11 06:05 PM
patrick
Grand Haven, MI
my experience with the XE262 in my 360, I installed it on the recommended 106ICL. For decent idle/best performance I needed about 20 degrees initial, 38-40 total, and I set my advance curve to start at ~1200 and be all in by ~2100 RPM. I had my neutral idle set at about 950RPM, which put it at about 850 in gear, 780 or so with the A/C on in gear. with vacuum advance I was pushing ~55 degrees total timing. I never had detonation issues, and I never ran anything but 87 octane. measured/calculated compression was about 7.9:1
my current 318 with magnum heads has a 9:1 compression ratio, and I'm running a 259 degree adv, 208@.050 roller cam. cam is same intake and exhaust lobe, 112LSA, 108ICL. I've got initial advance set at about 17-18 degrees, total ~30-32 (where it performs best) with about 47 degrees total with vacuum advance. I never have had detonation issues on 87 octane with this combo either. cranking compression is ~155-160PSI
[Re: patrick]
#940633
03/02/11 06:29 PM
03/02/11 06:29 PM
Streetwize
Weddington, N.C.
Patrick, What's the @.050 with the XE262? Isn't it like 214/220 (or bigger)? Isn't that in the same range I'm calling for? I'd hesitate to go smaller than that cause you'll never feel it over a decently tuned stock 360. I've seen some bad results with open chamber heads (no quench) and some of the fast rate cams, particularly with tight converters. here in the sun belt the summer gas is not very good, I'm just thinking a heavy truck would like a moderate but not XE fast ramp overall, but like I say, opinions vary! I run an XE284 grind in my 427 (SBF) Cobra, it's hyper responsive and works well with the adjuxstable valvegear (another common XE complaint you hear is when using OEM stamped rockers) but 500+ hp in 2400 pounds it's hard to load the motor up too hard anyway.
[Re: Streetwize]
#940634
03/03/11 02:14 PM
03/03/11 02:14 PM
patrick
Grand Haven, MI
Patrick,
218/224@.050....exhaust lobe is the same as the comp magnum 270H IIRC.
if I had to do it all over again, I would have gone with the XE256, I don't think I would have given up much if anything in the powerband I typically used, which was idle-5000 RPM, it would have been a bit better behaved at idle with the A/C, I might have gotten a little better economy (typically 15mpg in mixed driving), and it would have played nicer with the lockup/OD tranny. I had issues with surging at lower cruise RPM I think due to the cam sizing/overlap that didn't totally clear up until about 60mph (~2000 RPM). I think I woulda had a lot more drivability issues with a stock torque converter vs. the relatively loose 166k...I think it would have behaved better with magnum heads and the resultant nearly full point increase in compression. if going for something closer to [Email]218@.050[/Email], I'd probably look for a cam with a wider LSA like 112 or so, and possibly a single pattern to reduce overlap. I still think it's too big for a stock long block 360 in a heavy vehicle with stock stall, but my belief is short seat duration, aggressive ramps to maximize .050, and more importantly, .2" duration, and as much lift as you can get are the best bet to maximize torque and drivability.
my new roller cam in the 'teen uses bullet's HR259/316 lobes, which are "advertised" (.006" lift) only 3 degrees smaller than the XE262, the .050 is 10 degrees smaller at 208, but by .2" lift it's back to 3 degrees smaller (127 vs. 130), and it has .008" more gross lobe lift. I'm using the same lobe for exhaust, on a 112LSA, so I have significantly less overlap....drivability and fuel economy is much better with this 318, with no apparent loss in power over the 360, at least by the butt dyno.
[Re: smallstroker]
#940635
03/03/11 03:10 PM
03/03/11 03:10 PM
Posts: 164 mesa arizona
moturbopar
mesa arizona
I have new engle ep-18hyd cam, I wasnt planning on selling it but if you could use it I would. I have been saving it for a truck build, but I dont think that will happen anytime soon. the specs are. 260 adv dur 216 at .050 .458 lift on a 113lc has a powerband of 1500-5500
I think it would be a great truck cam, should have plenty of vaccum and probably do ok with emissions with the wider lc.
[Re: moturbopar]
#940636
03/03/11 07:06 PM
03/03/11 07:06 PM
patrick
Grand Haven, MI
wider LSA and I presume a single pattern cam, I'd probably use it, but I'd probably install it on a 105 degree ICL....
[Re: patrick]
#940637
03/03/11 08:24 PM
03/03/11 08:24 PM
Streetwize
Weddington, N.C.
That's pretty close to the Cam dynamics 266 I mentioned that's cut on a 112. The Engle 223@.050 I mentioned is a 110 split and is suprisingly tame at idle, but it comes on very strong from the upper bottom on up.
