Hyd Flat Tappet Lifter Recommendation for SB Stroker
#939777
02/28/11 02:23 PM
02/28/11 02:23 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I need a set of lifters for a 408 stroker that I am assemblying. The cam is a Racer Brown 238/238 @ .050 with out of the box Edelbrock Heads and springs.
I see Comp Cams makes a High Energy and a Pro Magnum any thoughts on which ones I need. Are there any other brands that may be better?
Thanks, Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
Re: Hyd Flat Tappet Lifter Recommendation for SB Stroker
[Re: goldmember]
#939781
02/28/11 06:01 PM
02/28/11 06:01 PM
finadk
East Brunswick, NJ
Thank you. I am sticking with the Hydrauics for this build. Scott
Scott
1976 Corvette
[Re: finadk]
#939782
03/02/11 11:29 AM
03/02/11 11:29 AM
finadk
East Brunswick, NJ
Just to close this out, the shop that sold me the stroker kit and comp cams both recommended the high energy litters for my build.
Scott
1976 Corvette
