Help With High Oil Pressure!
#93908
07/24/08 06:02 PM
07/24/08 06:02 PM
Posts: 1,019 Eau Claire, WI
ResQ911
super gas
super gas
Eau Claire, WI
I have a new 496 stroker engine. (125 mi.) I am getting 75 psi oil pressure at hot idle. Used a buddies spare gauge to check (Idles a bit high) 30 weight break in oil Melling HV pump My rallye dash gauge reads over high mark at 4000. I am guessing around 100 psi. What do you think? Thanks,
Re: Help With High Oil Pressure!
[Re: ResQ911]
#93913
07/24/08 09:44 PM
07/24/08 09:44 PM
Posts: 21,854 Kirkland, Washington
Pacnorthcuda
I have a new 496 stroker engine. (125 mi.) I am getting 75 psi oil pressure at idle. Used a buddies spare gauge to check (Idles a bit high) 30 weight break in oil Melling HV pump My rallye dash gauge reads over high mark at 4000. I am guessing around 100 psi. What do you think? Thanks,
I think in all probability you don't NEED or WANT that HV pump!
[Re: ResQ911]
#93914
07/24/08 09:46 PM
07/24/08 09:46 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
My 71 Bee
75 psi at idle - Will creep up till about 85-90 psi if i get on the throttle - OIL COLD
45 psi at idle - 75 psi cruising down the highway - Stays at 75 psi at higher rpms - OIL HOT
Melling high volume oil pump - Been running my motor like this since engine rebuild in 1999
Oil pressure hasnt changed in 10 years - Factory gauge cluster and Auto Meter Ultra-Lites
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: ResQ911]
#93915
07/24/08 09:50 PM
07/24/08 09:50 PM
Posts: 4,463 Rome, PA
Ryan_340
Rome, PA
I just helped a friend take the Melling HV pump out of his 340 and replace it with a standard Melling pump because of this same problem. It will ruin the bearings if you don't get it taken care of.
1972 Power Wagon W100
1973 Power Wagon W200
1971 Duster
1972 Dart Swinger
3-1972 Demons
[Re: bee1971]
#93916
07/24/08 10:05 PM
07/24/08 10:05 PM
Posts: 233 NH
Fastback67
NH
My 71 Bee
This sounds just about right to me
Best advice... contact the pump manufacture and get their opinion first before jumping to conclusions. I don't really see this as a problem...
[Re: CH3NO2]
#93921
07/24/08 11:26 PM
07/24/08 11:26 PM
ResQ911
super gas
super gas
Eau Claire, WI
stick one of these in and adjust it to whatever you want.
Where can I get one?
I think I will do an oil change and get the straight weight out of there before I do more.
I thought about switching back to a non-hv pump if that doesn't work. Just worried about this high of pressure.
Also kind of tired with the oil coming out breathers/covers all over newly painted everything.
[Re: stumpy]
#93925
07/25/08 01:28 PM
07/25/08 01:28 PM
ResQ911
super gas
super gas
Eau Claire, WI
Oil coming out of the valve covers is a blowby problem not an oil pressure problem. Are you running a PCV in the system or do you just have two breathers?
Two breathers
[Re: CH3NO2]
#93927
07/25/08 08:34 PM
07/25/08 08:34 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
where do you get this ?
