Re: Question about B and RB engines
[Re: Diego (not Ted)]
#939033
02/27/11 06:08 PM
02/27/11 06:08 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
GM & Ford have both got tall deck & short deck engines... It's fairly common practice...
Thing is Chrysler already had a taller deck height with the B than most other manufacturers... The engineers liked the tall deck to keep the rod angles down for long term reliability.. But making longer rods & tall pistons also increases weight which limits the engines ability to rev... Which is why strokers work so well in Mopars...
#939037
02/27/11 08:45 PM
02/27/11 08:45 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Both are canted valve motors, chamber shapes vary some but the same general idea...
BTW In my experience "Porcupine" is usually used to describe Big Block Chevy...
Ford's 351C, 351M, 429 all are canted valve as well..
#939039
02/27/11 08:50 PM
02/27/11 08:50 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I wouldn't think so.. There's always gonna be someone that will argue a detail but I think "Canted Valve" covers it leaving room for the subtle differences...
#939041
02/28/11 01:21 AM
02/28/11 01:21 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
All the polys have staggered valves
[Re: Alaskan_TA]
#939043
02/28/11 09:02 AM
02/28/11 09:02 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
RB = Raised block.
For an imaginary visual, take a 383 (B block) & add material to the deck, thus raising it from the crank shaft centerline.
Just think ov a 3/4" head gasket on both banks...
#939044
02/28/11 11:36 AM
02/28/11 11:36 AM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
Wow! I had to check and see if I had stumbled into the General Forum by accident................ Good to see you've decided to dig a little deeper into some technical detail. Must be doing research for a write-up........ Think NOT inline valves (SBC,SBF,SBM,BBM, BBF-FE), but mulitiple angles, meaning exhaust different than the intake to optimize valve angle for the respective port. Difference from there, Cleveland, 429/460, BBC, Poly are variations of that theme with their own angle of the valves with respect to the pistontop or deck of the block. Now, if we could just get you to turn some wrenches..........that's where the real fun is. ![](/ubbthreads/images/graemlins/wrench.gif)
[Re: Dean_Kuzluzski]
#939045
02/28/11 11:53 AM
02/28/11 11:53 AM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
In all reality its the configuration more than inches..i try to explain this to people but they dont get it.What makes a engine great for its application is the configuration more than the inches like the guy said on the 366/427 chevy..many a stud muffin drug them home from the yard thinkn they scored a hot 427..the 351w ford is a tall deck 302..like said all companys did it for various applications..
Best example i know of is the 352Fe Ford and the 360 Fe..a 360 is not just a 352 punched out..both of the same family but completly different bore/stroke..the 352 runs its @ss off and the 360(designed for trucks only..68to late 77 is a reliable pig ). This is not a low or tall deck example because the 360's tdc is bout a .500 before flush with deck and same block as 352 bout all about the combo of bore/stroke and as to poster on some engines they would alter the length of the cylinder to achieve this..(also creating a wider "V") 440's are awesome but i am hooked on my 451.revs like a 100,000mile 289.
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
#939047
02/28/11 01:44 PM
02/28/11 01:44 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Since you mentioned it...the 2 bolt mains, when all the "chivvy" guys have 4 bolt mains...
Doesn't the "deep skirt" of the big block that encapsulates the main caps the reason they don't need a 4 bolt main cap? all that block material on the sides of the main caps holds it in place, right?
Anyway...the 440 block definitely is way taller than it needs to be! I'm running a 440 crank and rods inside my 383 block, with custom pistons that are significantly shorter, but long enough to avoid piston rocking. at .060 overbore, I'm sitting at 438 cubic inches. just .010 more and it'd be a full 440 inside a 383 block.
**Photobucket sucks**
[Re: 70Cuda383]
#939048
02/28/11 01:52 PM
02/28/11 01:52 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
The register on the side of the cap is only about .250 , the rest of the cap is not supported in anyway by the deep skirts .
[Re: 70Cuda383]
#939049
02/28/11 01:59 PM
02/28/11 01:59 PM
Posts: 5,167 CT
GTX MATT
CT
I think the deep skirt makes up for it by offering extra support around the crankshaft. The 4 bolt mains on a Chevrolet engine are kind of correcting a design weakness I guess you might say. 2 bolts are too weak for serious performance use because there is no skirt. Its like using extra screws to hold a wall onto the side of a house because the wall isn't part of the frame work.
Im going to say that the reason our B/RB engines have 2 bolt mains is that Chrysler did not intend them to make 600+ horsepower with the use of aftermarket heads, cams, intakes, etc. The Hemi, which was designed as a race engine to be modified, has cross bolted mains which are way stronger than any four bolt main setup.
The only other deep skirt engines I know of from that era is the Ford Y block and Ford FE big blocks.
Considering that the first B engine was designed to propel luxury cars with ease, not really be modified for racing use, it is an extremely overbuilt design.
