440 connecting rod bearing question #938617
02/26/11 10:30 PM
02/26/11 10:30 PM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
The connecting rod bearing Caps have a slot cut in
them across the mating face,which,according to the service manual,is to provide oil to lube the cylinder walls,but the Clevite bearings I'm using,
have no matching notch in the bearing edge to
allow oil to get to that slot.. Is this proper?
Should a small notch be cut into the bearing edge?
Somebody got a picture of how the bearing should be?? Help please-would like to get Pistons installed in Block tomorrow..
Re: 440 connecting rod bearing question [Re: gassy66] #938618
02/26/11 10:47 PM
02/26/11 10:47 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Most replacement bearings do not have this as they found it unnecessary, there is enough oil splash without the squirt hole. Put it together and rest easy.
Re: 440 connecting rod bearing question [Re: MoparforLife] #938619
02/26/11 10:59 PM
02/26/11 10:59 PM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
Thanks for reply,feel better now.This is first Mopar I'm building,and I can't find diagram of
cylinder numbering in Service Manual.What's the
sequence? 1,3,5,7 on left bank(driver's side)and
2,4,6,8 right?? My name's Eric,and I am NOT as
smart as a 5th grader!!
Re: 440 connecting rod bearing question [Re: gassy66] #938620
02/26/11 11:12 PM
02/26/11 11:12 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I agree on the bearings,and yes you are correct on the cylinder numbering.
Keith
Re: 440 connecting rod bearing question [Re: gassy66] #938621
02/26/11 11:57 PM
02/26/11 11:57 PM
they stopped making the slot as they figured out that the walls get enough splash as is.
