where can you get a clutch type sure grip rebuilt kit? #938582
02/26/11 09:19 PM
02/26/11 09:19 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
can't seem to locate one. anybody know a good website?? 742 1967 plymouth
Re: where can you get a clutch type sure grip rebuilt kit? [Re: ngpSatellite] #938583
02/26/11 09:25 PM
02/26/11 09:25 PM
cbusters Offline
cbusters  Offline
Mancini. Just ordered me a clutch set for $79.
Re: where can you get a clutch type sure grip rebuilt kit? [Re: cbusters] #938584
02/26/11 09:27 PM
02/26/11 09:27 PM
own private Idaho
N
N
own private Idaho
thx bro!!
Re: where can you get a clutch type sure grip rebuilt kit? [Re: cbusters] #938585
02/26/11 09:34 PM
02/26/11 09:34 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
just make sure you check it and make sure it has the correct plates , there are 2 rebuild kits out there , one has all thick plates , the other has the correct thick and thin plates . you can fit the thick ones all in there but you will end up with a spool. The thin plates are usually at the end of the stack and they are spline to the case so you can just reuse your old ones by flipping them over because the one side is against the case that does not move .
Re: where can you get a clutch type sure grip rebuilt kit? [Re: JohnRR] #938586
02/26/11 10:09 PM
02/26/11 10:09 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
Who has the spider gears for this type of sure grip?
Re: where can you get a clutch type sure grip rebuilt kit? [Re: wannadrag] #938587
02/26/11 10:34 PM
02/26/11 10:34 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
DoctorDiff stocks individual pieces
New clutch packs $65
New clutch hubs/side gears (set of 4 pcs) $120
New spider gears (set of 4 pcs) $120
New thrust buttons $20 pair
OEM friction modifier additive $10 bottle
