At long last I am getting ready to get my project in primer. Long ago I sand blasted the shell (thankfully no warps) and have since replaced many parts. Are there any methods to get primer and then paint into many nooks and crannies? At O'Reilly's they sell a kit containing a long flexible clear hose which has a tip on the end which after pushing in locations like frame rails is suppose to rattle around and spray an undercoating while slowly being pulled back. I am considering buying this kit and before spraying the undercoat having some epoxy primer loaded into a spray can to use in the tight areas but I am looking for other alternatives. Any suggestions?
