I just got out for the first time in 5 months to work on my 66 coronet. It has a 5.7 hemi from a 2005 truck. I bought the power steering pump from S&P as well as all of their power steering hoses, overflow tank, and fittings. I had them take the return port off of another car and tap it so that their AN fitting would work with my old box. The last time I started it the power steering fluid leaked like crazy around the port on the top of the steering gear box. I finally got around to ordering the seal kit for the ports and put them in. Once I had everything reconnected and started the motor and noticed after a minute or so a whine coming from the motor and then I noticed the steering wheel turning on it's own. The whine got louder and I shut the motor off. Then power steering fluid started burping out of the top of the overflow tank. Can anyone tell me what is going on?
