Page 3 of 3 1 2 3
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938384
03/29/11 11:40 PM
03/29/11 11:40 PM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
Rear View
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938385
03/30/11 12:34 AM
03/30/11 12:34 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
What kind of driveshaft loop did you make for that extra short driveshaft?
Also is the TF a standard length or did you get a short trans from a truck with a divorced transfer case?
Re: 440 Powered Honda Civic!!? [Re: PHJ426] #938386
04/03/11 05:05 PM
04/03/11 05:05 PM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
It is a standard loop and sits just ahead of the center of the shaft.
It is a standard length trans.
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938387
04/04/11 01:25 AM
04/04/11 01:25 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Cool car, got any engine pic's? A guy I knew years ago had a civic with a 427 Ford with 8 injection stacks sticking through the hood, trans was a clutch flight.
Re: 440 Powered Honda Civic!!? [Re: rowin4] #938388
04/04/11 06:25 AM
04/04/11 06:25 AM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
Look at the first you tube video clip in the first post. You can see the motor in it.
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938389
04/04/11 03:17 PM
04/04/11 03:17 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Looking good with the new wheels!
Man, they have issues a ton of hobbyist plates since I moved! The ones hanging somewhere in my shop are (IIRC) three digits.
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938390
04/04/11 06:08 PM
04/04/11 06:08 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The Rocky is 86" as well.
WIZE
In Car:
Re: 440 Powered Honda Civic!!? [Re: Streetwize] #938391
04/04/11 07:08 PM
04/04/11 07:08 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
You are one very...very....sick puppy......... I love it! Are you gonna put wheelie bars on it, or maybe a pogo stick on top so it can right itself after it flips over backwards.
Man what a cool car! Good Job
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: 440 Powered Honda Civic!!? [Re: GTSDave] #938392
09/15/13 12:48 AM
09/15/13 12:48 AM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
Best run in paved 1/4 mile is 11.3@118. My converter slip thru the traps is 14% so I need to get it pulled out & tightened up. Hoping I can crack into the 10's.
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938393
09/15/13 12:51 AM
09/15/13 12:51 AM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
I got busy building this.
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938394
09/16/13 03:54 PM
09/16/13 03:54 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Page 3 of 3 1 2 3
