Page 2 of 4 1 2 3 4
Re: Anyone run Caltracs? Worth it? [Re: SV_MOPARS] #937994
02/26/11 09:00 PM
02/26/11 09:00 PM
ill
dennismopar73 Offline
ill
we purchased thru mancini 2 years ago ,
mono/ shocks and cals
same for ss springs too hahah
for the money we have in the rear of this car
we could build full 4 bar rear with all the dressings
and have gas money
Re: Anyone run Caltracs? Worth it? [Re: dennismopar73] #937995
02/26/11 09:11 PM
02/26/11 09:11 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
well not to sound cocky,but on a heavy 12 sec car,what kind of improv are goona really be seen,if the car isn't spinning the tires,and converter is good,maybe thats all she has
Re: Anyone run Caltracs? Worth it? [Re: B1KILLER] #937996
02/26/11 09:14 PM
02/26/11 09:14 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
My Boy ,One Bad Fish
Pic says it all
and dont forget pablo foot brakes that car!
Re: Anyone run Caltracs? Worth it? [Re: fishy340] #937997
02/26/11 09:23 PM
02/26/11 09:23 PM
ill
ill
well it had hd spring on it then
now with 474 alk
and diff 8 conv i would have thought
the car would run 10 60 10 70
with 123 plus mph the car now weighs in a 3560
with driver
the car started as a 12 sec car
it should be faster and it should 60 better than that
of a 12 sec car wouldnt ya??
being MR OBEVIOUS here
it not like we put junk together here
this has a complete moser 60 (a $2.500 rear)
nice small stroke to it on alk
went from 10 in tci conv
to 2 diff 8 ta conv
diff not a 12 sec car
but still run better on ss spring than on cals !
Re: Anyone run Caltracs? Worth it? [Re: DemonDust] #937998
02/26/11 09:28 PM
02/26/11 09:28 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
B1Killer,
One extreme to the other huh???
Yesir
Re: Anyone run Caltracs? Worth it? [Re: B1KILLER] #937999
02/26/11 09:37 PM
02/26/11 09:37 PM
ogden, utah
calmech67 Offline
calmech67  Offline
ogden, utah
67 Barracuda with caltracs, split mono, and rancho shocks, hooks great and strait 1.53 60ft. never has spun on take off yet. Yes cost was about $1100.00
Re: Anyone run Caltracs? Worth it? [Re: dennismopar73] #938000
02/26/11 10:07 PM
02/26/11 10:07 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
thanks eric for asking
this car is a 67 coronet
440 tweek to 474 now 8 ta conv 4200
on alk, dominator.
car started life as a 12.20 car 30 over 440, full stock inter say 3800 # w 430 gears 29 tire
we put some work in it put new hd springs on it
it then ran 12.0s sixty 1.67 -1.70
since those days it now has the 474 in it
410 gear same tire 29,
running alk and as only ran the best of 11.0 s
at 123 plus mph and 60 has been in the 1.67-1.68 range
we have 60 better with the ss springs at a 1.59
there is alot going on with this combo as you can tell by
the frustration in writting
this car should be running i think alot faster
as the mph suggest
as for cal tracks the money we spent vs the money we spent on ss
we do not see any pickup any where for that
we can rebolt the ss back on this car and have
and duplicated the 1.59 60 , so idono?
Dennis..am I correct in saying you used the HD springs with the Caltracs?...if so..that may have been the mickey in the works. The Caltracs work best with the mono or worn springs. Not very well at all with a SS or a HD spring. I'm not saying you guys don't know your stuff..but there are many out there, including myself, who have had great success with the Caltracs. Is a ladder bar a better race application..sure...even better with a 4-link in most cases...but the Caltracs do work for most...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Anyone run Caltracs? Worth it? [Re: calmech67] #938001
02/26/11 10:08 PM
02/26/11 10:08 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
guys have run 7's with them soooooo........
Mopar Performance
Re: Anyone run Caltracs? Worth it? [Re: Eric] #938002
02/26/11 11:05 PM
02/26/11 11:05 PM
ill
ill
no the car started out using hd spring
them we moved to ss
then we moved to cals mono shocks
we kept looking for why car would leave,
everyone said well cant run stock hd springs ,, so we went to a ss
then everyone said cals is the what ya need ,
which ever the wind blew we did to
spent money on gearing started with 430 went to 456
now we was told that the 474 would like 456 so it got 410
told alot ,
that whats bad ,
it just a sad tale to tell and there is more
but its just all sad
Re: Anyone run Caltracs? Worth it? [Re: moparniac] #938003
02/26/11 11:07 PM
02/26/11 11:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
Mustang 10.5 tire guys have run sixes with stock rear suspension As far as leaf springs running in the 8s or 9s Bob Brandt did that back in the early 1980s with a 1963 or 64 shoebox Nova with mono leafs on a set of 28x10x15 slicks corked up on the street and at LACR using a SB Chevy on squeeze I drive my duster on the street with ladder bars and coil overs, no big deal
Re: Anyone run Caltracs? Worth it? [Re: dennismopar73] #938004
02/27/11 11:29 AM
02/27/11 11:29 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
They work for me too.
Similar setup to dennismopar73- big boxy 3650 lbs w/me in 10.27@ 132 with 1.44 60 ft
What's not to like
And cost was no where near $1100.00
Re: Anyone run Caltracs? Worth it? [Re: dennismopar73] #938005
02/27/11 03:01 PM
02/27/11 03:01 PM
TMP66 Offline
TMP66  Offline
if he is ruuning a basic street car ss springs will be
all he needs
ss spring will run in the 8 -9 sec zone without any hassel!!
i have run stock springs at 11,0 s
there is alot of stupid things i have done thru out the years
waste money is one of them
there is alot to be said about the front end of the car
and making the car leave than tons of money spent on the rear
for no good reason
100%
When complaints rise about how bad S/S springs are I find in most cases it's incorrect pinion and shackle angle, not the springs.
Re: Anyone run Caltracs? Worth it? [Re: OA5599] #938006
02/27/11 03:51 PM
02/27/11 03:51 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Maybe my math is bad
$340 for the cal tracks
$340 for the mono spring
http://chucker54.stores.yahoo.net/catrbarsy1.html
$100 X 2 for the Rancho shocks
http://chucker54.stores.yahoo.net/rancho.html
comes out to less than $880??
Mine worked great but a sponsor is tubbing and ladder baring my car
so my buddy is taking them.
Re: Anyone run Caltracs? Worth it? [Re: Dodgem] #938007
02/27/11 04:13 PM
02/27/11 04:13 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Here's how I see it..........
To understand the basic fundementals of how the Caltrac's work........
they are a "Poorman's 4-link". And that's not a put-down. They turn the leafspring into the "upperbar" and work like a 4-link with some built-in slack (or not).
Where I'm situated...............
CalTrac's w/stock 4 or 5 leaf springs and drag shocks would be most cost effective.
Then, sell CalTrac's, to upgrade to a Ladderbar set-up if I'm going to mini-tub. Lose the weight of the leafsprings, gain tire clearance w/o the cutting to install the boxes to more the leafsprings.
Re: Anyone run Caltracs? Worth it? [Re: fishy340] #938008
02/27/11 04:36 PM
02/27/11 04:36 PM
Fort Worth, TX
Dago Red Offline
Dago Red  Offline
Fort Worth, TX
i'd love to see an 8 or 9 sec ss leaf spring car!! w a 8,9 or even a 10" tire..please show me?
Here you go...
If You Can't Be Good, At Least Be Colorful
Re: Anyone run Caltracs? Worth it? [Re: Dago Red] #938009
02/27/11 05:00 PM
02/27/11 05:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Here you go...
Is that Gene Buells car? If so, it never hit the 9`s............knew him well and did some work on his motor when I worked at Pettis. If not, my bad.
Re: Anyone run Caltracs? Worth it? [Re: OA5599] #938010
02/27/11 06:37 PM
02/27/11 06:37 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Cuda will be going for low compression 340 to a 550+ hp 418. I already have M/T Drag Radials, but have been recommended Caltracs. I'm a novice, so who here runs them? Are they worth the $$$ and hassle? Is there a better alternative? Not crazy about the traction bar look, but if it's necessary, I'll do what I need to for traction.
Thanks,
Bolting the cal-tracs to your existing springs will give you an improvement in traction without changing the ride stance of your car, all for about $340. The 9-way shocks are nice for additional adjust-ability, but not 100% necessary. The mono-springs will add a little more movement for extra traction if needed.
One of the nice advantages of the cal-tracs is being able to add pre-load to the passenger side to insure even traction on both sides for a straighter launch. Something that can not be done with SS springs.
SS springs will raise the back of the car about 2" which some feel is a "proper" stance for a Mopar. But now days, the "low" look seems to be more desired, and is my preference.
I have run SS-springs, Cal-tracs, and ladder bars on the street and the track since 1982. I remember adding 1/4" steel plates to the pinion snubber area for the SS springs as the original floor pan distorted. The ladder bars worked great, but rode stiff and noisy.
I feel that for a street driven car, the Cal-tracs are my top choice for a traction aid.
Scott
Re: Anyone run Caltracs? Worth it? [Re: Thumperdart] #938011
02/27/11 08:11 PM
02/27/11 08:11 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Here you go...
mine on a true 10"/28"
Re: Anyone run Caltracs? Worth it? [Re: B1KILLER] #938012
02/27/11 08:55 PM
02/27/11 08:55 PM
K
KOS Offline
KOS  Offline
K
not worth it in yur application.........SS and good shocks will be fine.i went from SS to the complete caltrac setup running mid to high 9s and only picked up a 100th in the 60ft on a small tire car.
Re: Anyone run Caltracs? Worth it? [Re: ProStDodge] #938013
02/27/11 09:35 PM
02/27/11 09:35 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Thanks,
Scott
I could not of said it any better
Page 2 of 4 1 2 3 4
