Re: A body torque box modifications?
[Re: moturbopar]
#937756
02/26/11 05:36 PM
02/26/11 05:36 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
IMHO, the torque boxes are a step (or two) below subframe connectors. In the '60's, the unit body construction was an engineering advance by Chrysler, and if they then added subframe connectors, it would be admitting a design weakness. In lieu of doing this, they came up with the torque boxes as a compromise(again my opinion).
But modern chassis' are very stiff to help handling, and I think for the most part they are a factory combination of unit body and subframe connector construction.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: ScottSmith_Harms]
#937758
02/26/11 06:03 PM
02/26/11 06:03 PM
GO_Fish
Maryland
Not wanting to put words in your mouth, but are you then saying that modern chassis' use torque boxes? Then again they may not be as necessary anymore since torsion bars and live rear axles are long gone...
Scott B.
