Sway bar bushings #937585
02/25/11 11:25 PM
02/25/11 11:25 PM
TN, USA
Ron TN Offline OP
Ron TN  Offline OP
TN, USA
I have a 73 E Body with front and rear sway bar. Both are stock with the rear being frame mounted. I need to replace the bushings for the bars. I think the fronts are readily available but have not seen, or overlooked, finding bushing for the rear (they have the factory U shaped clamp that mounts to the frame rails). Any suggestions on where to find the correct bushings for these bars? Thanks in advance.
Ron
Re: Sway bar bushings [Re: Ron TN] #937586
02/25/11 11:52 PM
02/25/11 11:52 PM
IN
ahy Offline
ahy  Offline
IN
Check out Firm Feel - they offer the factory style rear bar and would sell the bushings. Their bar may or may not be the same diameter as factory but either way they will likley be able to supply the bushings.
Re: Sway bar bushings [Re: ahy] #937587
02/26/11 12:17 AM
02/26/11 12:17 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
On an E-body, the rear sway bar straps(that hold the bushings) are welded to the mounting brackets. The bushings were not servisable. No one makes stock E-body rear swaybar bushings.
You can find the correct diameter poly bushings and cut them down to fit. They won't look stock though.
I just bought some used origonal bushings that are in good shape to replace my worn out origonals. I'm planning on priming the retaining straps with a weld through primer, installing the bushings, then weld the straps back onto the brackets.
Re: Sway bar bushings [Re: burdar] #937588
02/26/11 10:58 AM
02/26/11 10:58 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I picked up front bushings from PST for this 71 B Body. The straps are not available as far as I know. I blasted them and painted.
Re: Sway bar bushings [Re: Ron TN] #937589
02/26/11 11:02 AM
02/26/11 11:02 AM
TN, USA
Ron TN Offline OP
Ron TN  Offline OP
TN, USA
Thanks for the feedback. I suspected as much. I like the way the bar bolts on because it will not pull through mount holes like others I have seen have the possibility of doing. I will likely have to do something similar to what you are doing to install your original bushings.
Re: Sway bar bushings [Re: Ron TN] #937590
02/26/11 01:02 PM
02/26/11 01:02 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
on my 71 when i sent my rear bar out for chroming, i had cut the strap off the mount and welded studs on it and installed 2 new straps and bushings from another model with nuts...not factory,but back then in the 80's, no one cared....where did my numbers matching block go back then?
