Front Seal on a 8.75 Rear End #937555
02/25/11 09:10 PM
02/25/11 09:10 PM
Crofton, MD
bri440 Offline OP
bri440  Offline OP
Crofton, MD
How hard is it to replace the front pinion seal on a 8.75 rear end? What is envolved? Can I do it with the rear end still in the car?
Thanks,
Re: Front Seal on a 8.75 Rear End [Re: bri440] #937556
02/25/11 09:14 PM
02/25/11 09:14 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yes it can be done whiel in the car. Swing drive shaft out of the way from the yoke. Using an inch lb torque wrench turn the pinion and measure the resistance turning it. Remove the nut and pull the yoke and pop the seal off and replace and tighten the yoke to the torque reading gotten earlier.
Re: Front Seal on a 8.75 Rear End [Re: MoparforLife] #937557
02/26/11 12:47 AM
02/26/11 12:47 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
the in/lb torque reading may not work too well with the axles,brakes and tires installed?
When I did mine, I marked the nut, yoke, and pinion with a marker, then counted the number of turns it took to remove the nut so I could install the yoke and tighten the nut back to the same position after replacing the seal.
Re: Front Seal on a 8.75 Rear End [Re: 451Mopar] #937558
02/26/11 01:01 AM
02/26/11 01:01 AM
scratchnfotraction Offline
if its a crush sleeve its a 50/50 chance it will be ok when retorqued
if it crushes any amount it will be off and going south in short order
the 742 has a solid spacer and shims,the yoke can be R&Red and just retorque it to the correct setting
if you have a 489 with crush sleeve and have it rebuilt,set it up with solid spacers to avoid this problem of yoke change in the future
so..? is....do you feel lucky??
good luck with it
Re: Front Seal on a 8.75 Rear End [Re: scratchnfotraction] #937559
02/26/11 12:31 PM
02/26/11 12:31 PM
Crofton, MD
bri440 Offline OP
bri440  Offline OP
Crofton, MD
Thanks for all the help. How can I tell which rear end I have? It came in a 1971 Challenger RT - 340/auto. I'm guessing its original, ceratinly looks like 40 years of crud stuck to it.
Re: Front Seal on a 8.75 Rear End [Re: bri440] #937560
02/26/11 12:40 PM
02/26/11 12:40 PM
BDW Offline
BDW  Offline
Look on the driver's side of the chunk, it should have a casting.
Re: Front Seal on a 8.75 Rear End [Re: 451Mopar] #937561
02/26/11 12:45 PM
02/26/11 12:45 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I have done 5 seals this way at the shop I worked last year and they all still work perfect. You will need a good iimpact gun to loosen and retighten the pinion nut and you may need a puller to pull the yoke off . Your 71 should be a 489 case and 323/355 rear . Just check for the tag on the carrier bolts.
