Re: Question for the 72 RR experts.
[Re: JohnRR]
#937258
02/25/11 02:13 PM
02/25/11 02:13 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
If you do your homework and it looks legit, it probably is. Lots of things came out of the factories that really never should have been, they've been documented time and again.
[Re: Rosco]
#937260
02/25/11 10:26 PM
02/25/11 10:26 PM
Posts: 12,351 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Both the interior and exterior could be optioned up, so there were different styles available. The best source of this info is, of course, the build sheet. But there is also some trim info on the fender tag.
Master, again and still
[Re: Rosco]
#937264
02/26/11 12:40 PM
02/26/11 12:40 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
.Are the front valances the same from a 72 RR to a Satellite?
Yes same 71 and 72 2dr only... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Rosco]
#937266
02/26/11 12:55 PM
02/26/11 12:55 PM
Posts: 1,163 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
Is there any chance that a 72 Runner came with the Satellite Sebring Plus body moulding.The moulding starts at the front of the fender on the body line,follows above the wheel openings and all the way to the rear.The paint below the moulding is silver.The upper door panels also appear to be SSP style.The dash is black and the rest of the interior is Petty blue like the paint on the exterior.It also has a black half vinyl top. The dash tag and fender tag start with RM23 but I have a feeling someone swapped them to this car.I haven't been able to get the rest of the numbers from the fender tag yet.The car is for sale and I need to find answers before make an offer.Any ideas? Thanks.
Did you check the vin on the rad core support ?? Build sheet ?? Petty Blue interior ???
