Re: Mopar Performance assembly line oil filter
[Re: screamindriver]
#936790
02/25/11 11:17 AM
02/25/11 11:17 AM
[Re: ]
#936791
02/25/11 11:37 PM
02/25/11 11:37 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
...not that I have ever seen...
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
#936792
02/25/11 11:38 PM
02/25/11 11:38 PM
Posts: 21,471 It's a dry heat
gtx6970
It's a dry heat
Was the mopar performance resto oil filter {part number 77R06287} ever released ????
nope,, and I have my doubts it ever will to be honest
#936795
04/01/11 12:58 AM
04/01/11 12:58 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
According to Mitchel NOS parts, the factory oil filter was put on before the engine was painted; therefore the filter is coated with engine paint.
Anybody know anything or have opinions about this?
Anyhow, if so, that makes it easy and saves bucks.
[Re: kentj340]
#936796
04/01/11 10:37 AM
04/01/11 10:37 AM
Posts: 4,799 ILL
MLR426
ILL
I also thought filters were painted along with the engine and still do. At the Nationals last year I was docked points for my filter having orange paint on it, although I was also docked points for having the master cylinder cap painted black as well ? Although E -Body hemi bendix booster and master cylinder assemblies were painted as a unit together. Mine was NOS and painted as a unit. Go figure uh I was docked points on it, great judging. Rant over..
logan426
[Re: 52savoy]
#936797
04/01/11 10:40 AM
04/01/11 10:40 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Mopar makes the repo '62-'66? and early 70's filters. I was thinking awhile back of matching the green paint and have a stencil made that way I can repaint a few reproduction filters.
It would be for my own use so the question is..would mopar still be on my azz over it?
If you never posted it on the internet and you aren't going to sell them how would they ever know ???
[Re: gtx6970]
#936799
04/01/11 06:16 PM
04/01/11 06:16 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Don't give up hope just yet, the project has gone in a totally different direction .
[Re: rayztoy]
#936801
04/01/11 07:17 PM
04/01/11 07:17 PM
HEMICUDA
Medina, Ohio
The filter was just one of those projects that got shelved because of the bad economic times. Filter manufactures have a minimum run of 10's of thousands, they won't even look at it if you ask for hundreds. The manufacturing volumes required compared to the available market would make it a $100+ piece that you would have to sell thousands of. Not very marketable at that price for the volume you would need to sell. Having a standalone filter made like that one isn't in the cards, however, there are people looking at an alternative that may or may not be marketable. Making the filter from scratch isn't going to happen so, what if the original style housing was made and an existing filter was inserted into it? This is something I’ve been thinking about since the first time I tried to find an original. If this can be done and keep the price around the $29 mark would it sell? A project like this still will have a decent level of expenses, a deep draw die still has to be made, filter painted and stenciled correctly, then buying all the new filters. Still not a cheap endeavor for sure. I don’t think you’ll ever see, from scratch, this particular filter. The big question is, will the market accept this as an alternative?
[Re: MLR426]
#936803
04/01/11 11:43 PM
04/01/11 11:43 PM
Posts: 1,660 Cleveland, OH
TWS
Cleveland, OH
logan426
What judging class? 2010 Nats?
[Re: gtx6970]
#936804
04/02/11 01:35 AM
04/02/11 01:35 AM
Mike what about just making the exterior can to slide over a currently avail existing filter.
Then the end user simply pulls the visible exterior off of it, changes the actual filter then slides the psuedo exterior can back on.
Now obviously this only is a viable alternative IF all or at least the major filters avail all use a common outside dimension.
if something like this is in say the $20-$30 price range. I would think would sell well enough to consider it as an alternative to producing a full operational filter from scratch
Mike, I would be buying at least one, if not two for our cars if you were to do the above!
[Re: gtx6970]
#936805
04/02/11 09:55 AM
04/02/11 09:55 AM
JohnRR
U.S.S.A.
Then the end user simply pulls the visible exterior off of it, changes the actual filter then slides the pseudo exterior can back on.
Bill I think that was what he was saying in the post above ?
[Re: MLR426]
#936806
04/05/11 07:33 PM
04/05/11 07:33 PM
Me two. I am just having trouble seeing the redish engine paint on the oil filter because of all the green that seems to be covering it.
[Re: Paul Jacobs]
#936807
04/08/11 01:40 PM
04/08/11 01:40 PM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
I bought a low mileage wreck (like 2300 miles) that had it's original green textured filter on it, it had engine overspray on it, though I can't say they all did. I think it's the only engine I ever ran across with the original filter on it.
Sooooooooo....did you overspray my Mopar filter? I'll be checking and if you didn't the final payment will be reduced drastically!
