I have a 383 in my 70 Challenger, which just had a fresh rebuild by a reputable builder. Tranny is a 4 speed, carb is an Edelbrock 1406, used because I couldn't find the 4367 I needed at time of the rebuild. Cam is new, stock grind, vacuum advance is connected, stock everything, timing set at around 36 degree total (that sound right?)
Ever since the rebuild, the car has had a major hesitation/bogging when throttle is applied from any rpm. For example, setting in my garage, at any rpm from idle to 4000 if the throttle is depressed it hesitates. Badly. It's even worse when I'm driving it around- the car often dies or backfires. The car starts easily, idles nice, choke works as it should.
I have heard the 1406 has a reputation for an off-idle hesitation, but this occurs at any rpm, not just idle. I have tried using all holes on the accelerator pump rod (if that's what it's called), and it makes no difference at all.
Here's the kicker- I am only pulling 12" of vacuum. What are you guys pulling on stock 383's?
Oh, ignition is stock Mopar electronic. I have changed ecu units- no difference.
