turbo charger and super unleaded gas... is it a must!! #936588
02/24/11 08:01 PM
02/24/11 08:01 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
With all the knowledge on this board,i figured id ask you guys first
i have the opportunity to acquire a Subaru WRX sti ( i know,i know not a mopar). Manufacturer says to operate with minimum 91 octane. under normal driving conditions, could i fill up with 87 or 89 octane?
thanks
Re: turbo charger and super unleaded gas... is it a must!! [Re: mxbeep] #936589
02/24/11 10:52 PM
02/24/11 10:52 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Putting around yes but it will probably "ping" when you open her up.
Mopar to the bone!!!
Re: turbo charger and super unleaded gas... is it a must!! [Re: 72Swinger] #936590
02/24/11 10:54 PM
02/24/11 10:54 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Don't do it. Technically if you never get into boost 87 would be fine, but trust me you will. Don't be cheap, buy premium.
Re: turbo charger and super unleaded gas... is it a must!! [Re: mxbeep] #936591
02/24/11 11:20 PM
02/24/11 11:20 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Boost is as addictive as meth or heroin. Buy the good gas cause you won't be able to stay out of the throttle.
Re: turbo charger and super unleaded gas... is it a must!! [Re: 67_Satellite] #936592
02/25/11 01:04 AM
02/25/11 01:04 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Octane "GOOD"
Detonation "BAD"
If you hear pings its probably too late. Melting piston!
Burn no less than 92 octane IMO!!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: turbo charger and super unleaded gas... is it a must!! [Re: CUUDAK] #936593
02/25/11 01:32 AM
02/25/11 01:32 AM
Reno, NV
W
Wilde Racing Offline
W
Reno, NV
Late model computers will be able to compensate for poor fuel quality. and on the same note you will get more miles per gallon running the better stuff. It will usually out weigh the cost....
Re: turbo charger and super unleaded gas... is it a must!! [Re: Wilde Racing] #936594
02/25/11 12:26 PM
02/25/11 12:26 PM
IL
furious70 Offline
furious70  Offline
IL
While this is true, if there's been any modifications to the wastegate actuation (manual controller, bleed, etc) then the ECU may not be able to compensate. It's only $2/tank for the good stuff, if you were really tight for cash you wouldn't be buying an STi anyway.....
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: turbo charger and super unleaded gas... is it a must!! [Re: furious70] #936595
02/25/11 02:15 PM
02/25/11 02:15 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
as nothing to do with being tight with cash!!, a few places where i travel do not offer 91 octane.
Re: turbo charger and super unleaded gas... is it a must!! [Re: furious70] #936596
02/25/11 02:22 PM
02/25/11 02:22 PM
Reno, NV
W
W
Reno, NV
No body said anything about modifications... Then all goes out the window.... Who knows if something has been done to the waste gate or timing tables.....
BTW gas is almost 4.00 a gallon here.
Re: turbo charger and super unleaded gas... is it a must!! [Re: mxbeep] #936597
02/25/11 07:24 PM
02/25/11 07:24 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Then fill up before you head out and try to avoid the 87 as much as possible. I would make sure to burn it all up and refill w/ 91 or better before getting on the throttle again.
Re: turbo charger and super unleaded gas... is it a must!! [Re: DaytonaTurbo] #936598
02/26/11 10:07 AM
02/26/11 10:07 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I can't say about Subarus but I have no problems with running a turbo mopar with 87 octane all the time as long as the proper intercooler is utilized and boost level is modest.
On my 12 second Daytona that was 15 psi in the summer and as high as 21 psi in the winter.
"I think its got a hemi"
Re: turbo charger and super unleaded gas... is it a must!! [Re: mxbeep] #936599
03/05/11 02:42 PM
03/05/11 02:42 PM
Tuscaloosa, Alabama
speedfreak440 Offline
Tuscaloosa, Alabama
http://www.lethalperformance.com/2010-sh...se-of-6-p-28089
Good stuff, I have used it myself, it is not a gimmick like the other "octane boosters" you see at autozone & such. Keep a 32oz. can in the trunk for when you can't get your hands on 91+
Re: turbo charger and super unleaded gas... is it a must!! [Re: CUUDAK] #936600
03/06/11 05:12 AM
03/06/11 05:12 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Octane "GOOD"
Detonation "BAD"
Hard to find higher than 91 around here
