Re: Solid Flat Tappet Differences
[Re: 10 o to go]
#936239
02/25/11 07:33 PM
02/25/11 07:33 PM
Posts: 1,134 OHIO THE HEART OF IT ALL
64hemi330sedan
We run mopars also they are lighter and been told 5 thousand under size. Comps are heavy . But I had a mishap last year with one ,nobody has seen this happen . We believe the lashcap broke and caused too much lash ,or the hole in lifter made too much lash broke lashcap . witch came 1st chicken or egg.
Pic of it
no lash caps here. ive been there done that more than once.been lucky so far.replace the lifter and pushrod if needed.and carried on.
Re: Solid Flat Tappet Differences/Update
[Re: Cuda_Mike]
#936242
03/25/11 10:15 AM
03/25/11 10:15 AM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
Anybody use these?
I used that style lifter in 440 with a small Ultradyne solid for 10 yrs(probably 50000+ miles) and then my brother used the same cam/lifters for the last 5 years. No problems at all.
[Re: Cuda_Mike]
#936243
03/25/11 12:18 PM
03/25/11 12:18 PM
Posts: 16,929 NC
440Jim
NC
Anybody use these?
I haven't bought any Bullet/Johnson solid lifters. So I don't know about the metalurgy/heat treatment/machining, etc.
IMO, the design/style is fine. Avoid excessive lash, valve float, incorrect pushrod tip dia, etc so the pushrod seat insert doesn't crack.
