Re: Front motor plate questions
[Re: 74-440Charger]
#936191
02/24/11 03:13 AM
02/24/11 03:13 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I'm definatly a fan of the Andy F plate. Gives you room for dry sump setups, Relocate the alternator lower, along with strengthening your front frame rails. Mine durring mock up Look for Andy F here on Moparts!
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: 74-440Charger]
#936192
02/24/11 03:37 AM
02/24/11 03:37 AM
Posts: 43,754 Bend,OR USA
Cab_Burge
Summit sales a 1/4 inch thick motor plate for full chasssis cars that sets the motor in the center, I have one that I'm going to use a stock front half car, I'll need to make the left frame bracket stick out a inch or so due to the motor being offset like stock, no big deal really I have used 1/4 inch thick elephant ears for years(bought from Bob Mazzolini) in A bodys, we would have the back of the water pump housing milled 1/4 inch so all the stock pulleys and brackets will work. The only thing you will need to change is the lower alternator adjuster arm and fan and alternator belt if you want to keep the stock alternator in the stock location BTW, I recommend usings studs on the block for the water pump and to locate the motor plate or elephant ears so you can change cam timing without having to support the motor with a jack or cherry picker later
[Re: 74-440Charger]
#936194
02/24/11 10:08 AM
02/24/11 10:08 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Remember, if you go with a motor plate some kind of fore /aft limiter is needed.
[Re: 74-440Charger]
#936195
02/24/11 10:37 AM
02/24/11 10:37 AM
Posts: 13,497 Marion, South Carolina [><]
an8sec70cuda
A 1/4" plate is plenty thick. The Comp Engineering plates are bigger and solid (no cutouts) so you can cut it to fit however you want. Plus you have more room to mount stuff on it. I have one on my car w/ NO midplate. Just make sure you use a fore/aft limiter.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: 74-440Charger]
#936197
02/24/11 03:29 PM
02/24/11 03:29 PM
WILD BILL
BROOK PARK, OH
I have a 1/4" Plate (I think) and with out a limiter I can move the motor for and aft quit a bit due to the plate flexing.
I posted a thread a little while back on these and it has all kinds of pics and ideas.
If you can't find it I'll post a link or maybe some pics of mine when I get home from work later tonight.
[Re: 68roadrunner]
#936203
02/24/11 10:26 PM
02/24/11 10:26 PM
Posts: 10,613 Rittman Ohio
fourgearsavoy
Rittman Ohio
AndyF makes the best plates because his plate has the factory offset built into them I also second the fore/aft engine limiter or you will bend even the best plate DAMHIK Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 74-440Charger]
#936207
02/25/11 02:30 AM
02/25/11 02:30 AM
Posts: 31,203 Oregon
AndyF
Good idea, Big block pics please and price/order info would be appreciated also.
Mancini Racing has the plates. So does Hughes Engines.
