Re: Approx. hours for a partial rotieserre resto...
[Re: DPelletier]
#935976
02/24/11 07:34 PM
02/24/11 07:34 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Typically shops have a minimum of 250-300 hrs just for prep and paint on the exterior body, you're talking about doing the complete underside as well. You've done restoration work in the past so you should have an idea of how much time it will take to dismantle and strip the shell...
I personally think you're robbing yourself if you quote anything less then 500 hrs...
....and if Alan says 500, you should probably plan on 600! mine took 600 and I had taken the car apart and got it back as a rolling shell.
Unless a car needs a lot of panel replacement, I just don't see how I could possibly have double the hours into it. And I do all the body work by hand. No air file, don't use a da and so on... just a hand grinding for welds and a larger angle grinder and stripping discs for the paint.
Maybe I'm too critical of the time, I go in the house and grab a can of pepsi, that's 5 mins I'm not charging for
[Re: Challenger 1]
#935980
02/24/11 07:52 PM
02/24/11 07:52 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
I don't do body work, never have, probably never will. However I've had dozens of cars painted by several body shops over the years... This is how it was explained to me... It takes approximately 3 days to take one panel from bare metal to finished paint... That includes prepping the metal, epoxy prime, filler work, sanding, priming, block sanding, final prime, guide coat, final blocking, paint, clear coat, denibbing, polishing. That is approximatey 24 hrs labour. NOW: Most cars have 8-10 panels...2 fenders, 2 doors, 2 quarters, hood, trunk, roof, valances. Simple math: 8 X 24 = 192 / 10 X 24 = 240 In other words the average car takes 200hrs - 250hrs Now, if you're thinking that I'm still high...notice I didn't count the engine compartment, door and trunk jambs, trunk floor, any special attention to sound deadener, etc...etc...AND I haven't even considered doing anything to the bottom of the car.... I stand by my estimate of 500 hrs
CHECK OUT MY NEW WEB SITE !
[Re: anlauto]
#935981
02/24/11 08:19 PM
02/24/11 08:19 PM
Posts: 1,039 INDIANA
Paul Jacobs
INDIANA
500-600 hours for sure. To what extent are you going?? A basic job may be 300 hours BUT: Are you but welding everything & finishing off both sides? Are you putting lead back where it goes? Are you putting back all the proper sized spot welds? Are you mocking up everything that can change body gaps AFTER the car is assembled? Are you putting drip in the primer on the floor pan & bubbles in the floor pan where it pools? There are certain things that should be bolted on that stress the cars body/doors etc. I have no surprises me when I'm done. This stuff takes time but you get a killer job when it's finished! Plus some guys are naturally quick at some jobs, but bodywork is one thing that will come back to bite you if rushed!
[Re: Paul Jacobs]
#935982
02/25/11 02:55 AM
02/25/11 02:55 AM
Silver70
Rust Belt, SW PA
I see where your coming from Alan. Although I think that number would be on the high side for parts that just need stripped, primed, blocked painted... but I guess as a general number that could be about right.
As far as the extend of making it original, this car is going to be more of an over restored car which the underside being shiny and not with the factory runs, over spray and so on. There were no panels replaced, just some small patched on the trunk and one quarter. As far as bolting on panels and linign everything up, yes to all that. I'm not sure I'm fast at it as much as it's been a pretty easy project compared to most. Now replacing panels and such, that I would say I can do quickly. I have as much experience doing collision work as anything and that part I always found easy.
[Re: Silver70]
#935983
02/25/11 01:44 PM
02/25/11 01:44 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Well the crowd has spoken and the message seems to be fairly consistent. People like Paul and Alan do this stuff every day. Any big variances you are getting are due to two things only;
- differences in scope
- differences in quality
I'm sure you are doing a quality job so any differences would be scope related. In my case my bodyshop may have spent 10-15% longer as they aren't mopar specialists and I had to do most of the research and explain it to them......but at the end of the day, I'm confident that I got what I paid for and it was well over 500 hours. Of course every car is different as is every resto.
What I'd be interested in from some of the participants on this thread is how long do you think a total restoration goes? EVERY nut, bolt, bodywork, paint, mechanical systems, machine work, sub-assembly restoration: EVERYTHING.....1000 hours? 1500?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: anlauto]
#935984
02/25/11 01:45 PM
02/25/11 01:45 PM
Posts: 1,054 Roswell, GA - near Atlanta
cloneguy
super street
super street
They just did it in 6 hours on TV a few nights ago. That must be the new benchmark. (Although that was the losing team.)
[Re: DPelletier]
#935985
02/25/11 04:38 PM
02/25/11 04:38 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
To me the bodywork/paint is fairly straight forward. The only caveat is the condition of the vehicle. The other stuff is way more subjective. Bolts for instance. If you by the correct bolts new from your favorite supply house and just replace upon assembly that saves time. If you are anal, as I am, and want every fastener that came off the car put back on it then the time really piles up. You have to inspect the old ones. Decide what is savable then clean them and send them out for plating. I prefer the latter even though I usually loose my ass on jobs like that. It is not just a correctness thing but a carma thing for me for a car to have as many born with parts put back on. The bolt example is just one of a bunch of the smaller things that really pile the hours/cash up in a hurry. Instruments, do you do them yourself and spend the hours or contract them out and save time but spend money. I would loosely say, if you go the anal route, and no sub contracting and all out of my or I should say one shop 2000 hours would not be out of the question. I know some White Post type guys that tell me a Duesenberg or high end MB type vehicle can get up to 5000+ hours.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: formula_s]
#935987
02/25/11 08:34 PM
02/25/11 08:34 PM
Posts: 492 Kansas
BEINGmeISaCRIME
Kansas
Does 350 hours sound realistic? I read a site from a member here that said a typical top side resto will take about 300 hours.
Only if you let Maaco do it.
I lol'd at this.
A rotisserie will make that undercoating much easier. I had to do it from laying under the car and scraping.
Seems like heating the metal up from the backside with some form of heat and then scrape it off with a puddy knife/gasket scrapter/ect will make it easier. Whatever is left can be easily blasted off. Just my
[Re: DPelletier]
#935988
02/25/11 08:48 PM
02/25/11 08:48 PM
Posts: 2,304 WI
RestoRick
WI
One more factor not mentioned, when speaking of a turnkey type resto, is what model it is and how many options it has. There's a world of difference in hours between something like a nice complete '65 Satellite non-air, manual everything strippo vs. a '71 Cuda convertible with a/c, PS, PB, power windows, 6way seat, etc, etc... Lots of extra parts to spruce up and get functioning correctly. Also, extra or more complicated trim & brightwork adds more time.
Rick
[Re: RestoRick]
#935989
02/26/11 12:15 PM
02/26/11 12:15 PM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
FWIW; I am not a paint & body man but will tell you the above estimates of manhours is extremely hard to determine due to all of the unknown factors of hidden rust, previous repairs, etc. I just had my '69 Road Runner done by a very reputable shop, wins Gold at the Mopar Nats quite often, and the final bill came out much higher than he or I were planning on. The car needed new quarters, a new hood, outer wheel wells replaced, new trunk pan & trunk extensions, work on the doors, fenders, etc. The car was structurally sound, no work to the roof, A or C pillars but it still took a lot more time than anticipated. When the shell was delivered it already had the old quarters removed, the shell had been acid dipped and hand sanded and put in epoxy primer (I did that)and yet it took 678 manhours to complete the paint and body work. The 678 manhours did not include any re-assembly other than hanging the doors, fenders, hood and trunk. Now, this was not a partial restoration, it was full blown to replicate the way the car rolled off the assembly line and it is absolutely georgeous and correct, even the spot weld replications, drips in the underbody primer, overspray, etc. I would think 400-500 hours would be pretty close depending on the extent of the work and the extent of hidden issues. I have had 2 paint/body men tell me to plan on 100 manhours for taping, painting, color sanding and buffing once it's ready to hit the paint booth so that leaves 300-400 hours for everything else, that's 10 weeks on the high side @ 40 hours per week. Just my
[Re: Mopar Grandpa]
#935992
02/26/11 04:47 PM
02/26/11 04:47 PM
cloneguy
super street
super street
Like you, when we die we won't be able to take anything with us. So, we figure there's no need to keep much extra on hand while we're here.
Seriously, we have average life styles in rural GA. Our overhead is next to nothing and we enjoy what we do.
We're also pretty good at what we do. We can't touch Alan when it comes to sub assembly restoration or reassembly but we fly when it comes to metal replacement, body and paint.
To clarify, I was comparing to the 678 hours you mentioned above. For $18k, we do the metal, body, paint, polish and body assembly and you do the final reassembly. Or we can do it but it's not included in the $18k price.
[Re: anlauto]
#935994
02/26/11 05:46 PM
02/26/11 05:46 PM
Silver70
Rust Belt, SW PA
$26.55 per hour...
That'd be a raise for me
[Re: anlauto]
#935995
02/26/11 09:30 PM
02/26/11 09:30 PM
cloneguy
super street
super street
$26.55 per hour...
In fairness, we expect that we would be much faster than 678 hours to do the same job.
