Re: 72 Road Runner Wiring Question with Pics.
[Re: RRGTX72]
#935094
02/22/11 08:05 PM
02/22/11 08:05 PM
Posts: 80 Hawaii
RRGTX72
Hawaii
[Re: Yancy Derringer]
#935096
02/22/11 08:56 PM
02/22/11 08:56 PM
Posts: 1,647 IL
71383beep
IL
Those are the door switches in the frame of the door mounted to the body. They should have a plunger that goes to ground as the door opens. The first diagram showing the left side door shows 2 wires into the switch and one wire out. The 2 wires in are yellow (power) and black (ground I believe) and the last wire out (also yellow) goes to the dome light. As the door opens the plunger goes to ground connecting the circuit and powering the light.
The door switches are still quite common and available thru mancini, tony's, maybe even the local parts stores.
I think this is what your after right?
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: 71383beep]
#935097
02/22/11 09:20 PM
02/22/11 09:20 PM
Posts: 80 Hawaii
RRGTX72
Hawaii
Yes that is what I was looking for. So I just contact Manini's or Tony's and ask for the Right and Left Door switches that operates the dome light. Thanks 71383bee.
[Re: 71383beep]
#935102
02/24/11 12:02 PM
02/24/11 12:02 PM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
three pins are a little bit harder
[Re: RRGTX72]
#935106
02/25/11 02:12 AM
02/25/11 02:12 AM
NachoRT74
Valencia, España
an image worths million of words
( lights on buzzer is optional and part of the lighting package )
[Re: NachoRT74]
#935107
02/25/11 04:00 AM
02/25/11 04:00 AM
Posts: 80 Hawaii
RRGTX72
Hawaii
Nacho you rock. You must have known a redneck like me needs pictures. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RRGTX72]
#935108
02/25/11 08:46 PM
02/25/11 08:46 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
....and he knows guys like me like to save 'em for future reference. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RRGTX72]
#935111
03/06/11 12:28 AM
03/06/11 12:28 AM
NachoRT74
Valencia, España
the "wedged" plug simply gets an extra harness "extension" to get the buzzer... thats all, no more ![](/ubbthreads/images/graemlins/wink.gif) just like were posted on this same thread by 72roadrunnergtx Can be home made easily, the hardest part is try to find a "wedged" male plug. L shaped is not that hard since is the same that ALL AMERICAN CARS INDUSTRY turning and hazzard flashers use, and terminals are around at regular parts shops.
[Re: NachoRT74]
#935112
03/06/11 12:32 AM
03/06/11 12:32 AM
NachoRT74
Valencia, España
NOTE...
this same kind of plug is used to a harness runing underneath the carpet up to seatbelt retractors and seats sensors. This is not the harness what runs to this plug
The seatbelt sensor harness plugs on a same kind of wedged plug BUT containing blue wires, and located on driver side kick panel area
Maybe thats the confusion you are getting with an uncorrect harness for this purpouse
