Whats Going On With My Fuel Pressure?
#934831
02/22/11 09:06 AM
02/22/11 09:06 AM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
I just finished completely R&Ring the fuel system on my Coronet. New tank, pickup, fuel lines, pump, filter and rebuilt and deep cleaned the carb (a Street Avenger 875)
Problem is Im getting terribly low fuel pressure. I dont have a psi guage but when you get on it, the car stumbles and sputters and its not pulling enough vacuum to even fill up the (see-thru) fuel filter. It idles just fine and if I feather the throttle enough it will pull enough fuel through. But when its running, its just spurting through the filter. I pulled the rechecked the pump to make sure it was sitting on the pushrod correctly and it was OK. I also checked all the fuel lines. I richened up the mixture as much I could to see if that would help with fuel delivery and it didnt really make any difference.
The pump is a NAPA replacement part for a Hemi, which I figured would be substantial enough to feed my 875.
Re: Whats Going On With My Fuel Pressure?
[Re: RangerDan440]
#934832
02/22/11 09:14 AM
02/22/11 09:14 AM
moparpollack
Lil Herman
Lil Herman
85086
Could be a bad fuel pump rod the new ones are soft and mushroom that or you got a bad fuel pump.
[Re: RangerDan440]
#934833
02/22/11 09:17 AM
02/22/11 09:17 AM
RapidRobert
vac leak or accel pump prob
[Re: RapidRobert]
#934834
02/22/11 09:50 AM
02/22/11 09:50 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Is the tank vented through the cap?
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: RangerDan440]
#934837
02/22/11 12:55 PM
02/22/11 12:55 PM
Posts: 309 Hampden, Maine
Procommuter
super street
super street
Hampden, Maine
Some of the aftermarket sock filters that slide onto the fuel pick-up inside the tank go on to far. That blocks the end of the pick-up because it is up against the inside of the sock. If you find that this is your trouble just cut the end of your pick-up tube off at a 45° angle.
Wes
73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
[Re: RangerDan440]
#934838
02/22/11 08:58 PM
02/22/11 08:58 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Crack the gas cap loose to make sure the tank and/or the cap is breathing properly. A sealed tank will lead to no fuel pressure, especially when using the stock fuel pump. It may run okay on a cold start, then get progressivly worse fuel pressure as vacuum builds in the tank.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#934839
02/22/11 09:32 PM
02/22/11 09:32 PM
RangerDan440
thanks for the replies guys, much appreciated It was too cold to do anything on the car today. the tank is vented through a tube at the front and not the cap (its a 1968 Coronet with a pre-EEC tank) Im wondering since I havent filled it with a full tank of gas yet (only about 5 gallons to get it running) would that have anything to do with pressure build up inside the tank? Ive replaced tanks before and never had a fuel psi problem. I think I'll try and run it without the gas cap and see what happens. I just feel like the problem is in the tank. Ive tried 2 other pumps on it-a stock 440 pump and a Holley HP one and Im still not getting the psi I need. How about the power valve or accelerator pump?
