Page 7 of 13 1 2 5 6 7 8 9 12 13
Re: New 5.7 hemi eagle head [Re: MattW] #934417
02/25/11 02:10 PM
02/25/11 02:10 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
4NX5 7LTK203310871
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934418
02/25/11 02:22 PM
02/25/11 02:22 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
The general consensus is the first # is the year so 04 letter I THINK month DEC. 5.7 TRUCK FOR TK.
If you have the ignition wires crossing over the intake you have and early model. I think 06 it stopped. Hope this helps. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934419
02/25/11 02:44 PM
02/25/11 02:44 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
it does have wires going over the top. i was scared because the part number you put up for the heads is the same part number on my heads on the engine except the letters at the end of the part number. this is number on the head 53021609ba
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934420
02/25/11 03:03 PM
02/25/11 03:03 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I wish I could download my pictures. If you pull your logs off and you have a D shape port then you have 09 head. Maybe somebody switched the heads already. Congrats you have two sets of heads. Lol
I am almost positive you have a 2004 block. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934421
02/25/11 11:29 PM
02/25/11 11:29 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
heads came today
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934422
02/25/11 11:31 PM
02/25/11 11:31 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
castings are so smooth
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934423
02/25/11 11:33 PM
02/25/11 11:33 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
chambers
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934424
02/26/11 12:12 AM
02/26/11 12:12 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
exhaust
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934425
02/26/11 12:49 PM
02/26/11 12:49 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
is that intake and a mod man the only carb intakes for the new hemi?
Steff, is your car running yet? i'm looking foward to hearing how it runs
I thought this one was kind of cool.
TR Waters
Re: New 5.7 hemi eagle head [Re: MattW] #934426
02/26/11 03:20 PM
02/26/11 03:20 PM
Robbinsville, NC
nitroram33 Offline
nitroram33  Offline
Robbinsville, NC
Much as I like the Gen 3, don't forget the discontinued
59 degree W9 also flowed 300 out of the box and had potential above and beyond that.
But comparing an aftermarket race head to a dirt cheap OE production head ain't exactly fair
As far as the block taking it goes, there is a reason MP built the 392 at std bore, and it was not out of laziness. Don't bore it. It will surprise you.
They need to start racing these things in roundy round cars then I think people would start buying. Matt
Penske has done their research on them years ago and asked permission from NASCAR to use it and they said No. gotta love that [/quote
Never mind the big leagues go with grass root get enough demand and .......
So if the new srt 8 is using the 5.7 Me thinks the 6.1 is on the chopping block.
Hey ZIPPY PLEASEEEEEE ask them to turn the 6.1 into a siameses bore block before they they scrap it. Matt
The new SRT-8s are using the 6.4L and the 6.1L is dead.
RaceMagnum.com A home for late model EFI Dodge trucks and a sense of humor.
Re: New 5.7 hemi eagle head [Re: MattW] #934427
02/26/11 03:22 PM
02/26/11 03:22 PM
Robbinsville, NC
nitroram33 Offline
nitroram33  Offline
Robbinsville, NC
Already did, about a year ago or therabouts.
Response was aluminum, aluminum, and aluminum.
That was the end of that
Yeah I figure they are catering to people with money.
I just read that the 392 is only going to be 1492 units, so maybe the 6.1 isn't dead.
The "392 Edition" is what is limited production, the 6.4L will go into all the new SRT-8s.
Re: New 5.7 hemi eagle head [Re: MattW] #934428
02/26/11 03:29 PM
02/26/11 03:29 PM
Robbinsville, NC
nitroram33 Offline
nitroram33  Offline
Robbinsville, NC
Now I read that the 2011 srt 8 challenger is using the 6.1 block and not the 5.7 as I previously stated.
With a 4.09 bore I don't think the 5.7 block could handle it.
It is also coming with roller rockets. I like to see the part# and pricing on them. Matt
SE - 3.6L Phoenix V6
R/T - 5.7L HEMI
SRT-8 - 6.4L HEMI
Re: New 5.7 hemi eagle head [Re: TrWaters] #934429
02/26/11 08:05 PM
02/26/11 08:05 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
a guess, hot heads intake for a 392 with adapter plates?
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934430
02/26/11 08:48 PM
02/26/11 08:48 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
got this on the net." now for the useful stuff.
Cylinder heads. big changes here, new closed chamber heads have smaller chambers (duh) than previous engines , 66.3cc in fact vs 84.9cc. even smaller than the 6.1's with 73.0cc. bolting these on to a previous hemi without modification would result in nearly a 12:1 compression ratio. valves are slightly larger. intake is 2.05" vs 2.00". exhaust is the same. both valves have a longer stem though. new bee hive valve springs, identical on both intake and exhaust are now in use, and seem to mimic what we have been doing in using the 6.1 exhaust springs across all valves. pushrods have changed as well, they are now approximately 4mm longer, putting them very close in length to the 6.1's pushrods.
ports appear to have a 6.1 sized window on the intake side, as well as a 6.1 style D shape on the exhaust. a quick comparisson with a 6.1 exhaust manifold looks like it was nearly a perfect match.
tappets: i wouldnt normally cover this, but i actually made notes in class because of this. they have been revised for higher lift with proper MDS actuation. the stock cams have higher lift, requiring more capacity to collapse in MDS. the new lifters do this constantly in factory form. further more, they are backwards compatible. they will drop right in to an older 5.7 (or any previous hemi built with MDS)
intake manifold: this is a gray area, as there are approximately 4 or 5 different manifolds available for use on the eagle. the trucks use an active intake version where as the cars do not. the active intake allows the ram to have 390 horsepower and 404 ft*lbs of torque by giving it short and long runners in the intake. a very cool design, but nothing groundbreaking, v6's have it as well.
Once again not my info. Matt
Re: New 5.7 hemi eagle head [Re: nitroram33] #934431
02/26/11 08:53 PM
02/26/11 08:53 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
R/T - 5.7L HEMI
SRT-8 - 6.4L HEMI
I was referring the the 6.1 block. It's good to know that the 6.4 is going to be used in all srt8. That means that the bigger crankshaft will be for sale. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934432
02/26/11 09:26 PM
02/26/11 09:26 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Matt, make note of this, my heads have the same part number but are completely different.
the only difference with the part # is the letters at the end of the part number
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934433
02/26/11 09:50 PM
02/26/11 09:50 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Yeah you would think they would change SOME of the numbers.
Is there any info on the year of your block. I would like to know if my info is correct. If not I would like to know how you tell the different years.
Are you planning to run with a carb or EFI?
Matt
Re: New 5.7 hemi eagle head *DELETED* *DELETED* [Re: sixpackgut] #934434
02/26/11 10:18 PM
02/26/11 10:18 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Post deleted by MattW
Re: New 5.7 hemi eagle head [Re: MattW] #934435
02/26/11 10:36 PM
02/26/11 10:36 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Matt
no clue. ive called dealerships. i have a thread on the LX forums. no one knows. you may be right though
i'm a carb guy. i dont like sensors
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934436
02/28/11 09:59 PM
02/28/11 09:59 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
