Re: New 5.7 hemi eagle head
[Re: 540challenger]
#934397
02/24/11 01:54 PM
02/24/11 01:54 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Really LOL.I don't think they run my test cells do they? You said production tune.Maybe you need to do some research.
Leave the gun.......take the Cannoli's....Mike
[Re: wldtm]
#934401
02/24/11 02:56 PM
02/24/11 02:56 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
What is a Eagle intake
basically the car 09 intake manifold. similar to a 6.1 intake but not aluminum and not as pricey.
guessn around 230$ price range. drag pack intake = 1k$ list
Can this intake be used on an 03-08 production car or truck. I am not talking about physically bolting on, I think I read that the intake was a variable design. Something to do with runner length? Is it compatible with the 03-08 computer.Matt
The production SRV intakes are not compatible with earlier 5.7L or even 6.1L engines.
I have 09 heads bolting on to an 04 short block. I plan on using an 09 eagle intake with aftermarket EFI to run the system.
If you look at lxforums.com they have good info on the 09 eagle intake swap on to older engines. Adapters are avaiable for this swap it appears.
I think the gain comes from the combination of cam, heads, intake package. Not just one of the three.
On an 09 LC (challenger intake) i see no tuning valve listed in description and operation on dealerconnect. If needed I will take the intake off to find out.
justin
Thanks Justin this is the info we need. I glad you understood my question. Matt
[Re: MattW]
#934405
02/24/11 04:08 PM
02/24/11 04:08 PM
MattW
Ontario Canada
Much as I like the Gen 3, don't forget the discontinued 59 degree W9 also flowed 300 out of the box and had potential above and beyond that.
But comparing an aftermarket race head to a dirt cheap OE production head ain't exactly fair ![](/ubbthreads/images/graemlins/laugh2.gif)
As far as the block taking it goes, there is a reason MP built the 392 at std bore, and it was not out of laziness. Don't bore it. It will surprise you.
They need to start racing these things in roundy round cars then I think people would start buying. Matt
Penske has done their research on them years ago and asked permission from NASCAR to use it and they said No. gotta love that [/quote
Never mind the big leagues go with grass root get enough demand and .......
So if the new srt 8 is using the 5.7 Me thinks the 6.1 is on the chopping block. Hey ZIPPY PLEASEEEEEE ask them to turn the 6.1 into a siameses bore block before they they scrap it. Matt
Now I read that the 2011 srt 8 challenger is using the 6.1 block and not the 5.7 as I previously stated. With a 4.09 bore I don't think the 5.7 block could handle it. It is also coming with roller rockets. I like to see the part# and pricing on them. Matt
[Re: MattW]
#934406
02/24/11 04:48 PM
02/24/11 04:48 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
Ralph Gilles (Dodge CEO) said the 6.4L was very capable of making 500HP but torque would suffer (per the engineers), so they did what they did to get 470 lb-ft out of it instead. Its in here http://www.youtube.com/watch?v=tdkgFBf4ZJk
[Re: patrick]
#934408
02/24/11 11:05 PM
02/24/11 11:05 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
so $499 for the heads and $3000 for rockers that dollar cost averages to $3499 for a 700+hp set of heads...? whats the dilema? cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#934409
02/24/11 11:12 PM
02/24/11 11:12 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
I wouldnt even touch a set of adjustable rockers until they are needed. Stick with a hydraulic roller and use custom pushrods, then worry about the adjustable when you are making that big power number...
The LX cars have been making big hp for awhile with strokers and no adjustable rockers, I would wait for the aftermarket to catch up and hold out. Thats what I am going to do...
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: wldtm]
#934410
02/25/11 12:37 AM
02/25/11 12:37 AM
Posts: 793 Utah
topbrent
Utah
wldtm:
Few questions for the Gen III experts. Sorry if these are rudimentary and covered elsewhere...:
- How much lift can the stock rockers handle?
- How much spring can the stock rockers handle?
- At what point do the stock rockers become unsuitable, a liability, and/or unstable?
- Can you sufficiently cam the engine to use the higher lift flow that is available and still use the stock rockers?
- Can the stock rockers handle .600+ lift?
#934411
02/25/11 08:54 AM
02/25/11 08:54 AM
MattW
Ontario Canada
You know I was thinking the same thing. I am moaning about having no iron race block to play with. We do have the aluminum at 4000.00. If they were to come out with an iron block it would probably be around the same price as an R3. So yeah your R paying more but it is lighter and you can repair it. The heads are cheap and plentiful. In the long run I THINK it would be cheaper than an R3 build. Matt
[Re: topbrent]
#934412
02/25/11 11:39 AM
02/25/11 11:39 AM
Posts: 473 MI
Blown69
mopar addict
mopar addict
MI
wldtm:
The stock valve springs are 98#'s @1.77 (closed), and 242#'s @ 1.28 (open). Yes, the stock rockers and handle .600+ lift, many guys have been doing it for a long time. Manley makes direct replacment springs that will handle up to .650 and there are many companys out there making cams that will use all that lift.
[Re: sixpackgut]
#934414
02/25/11 01:06 PM
02/25/11 01:06 PM
MattW
Ontario Canada
is there no way to tell what year these new hemi engine are? i have posted this question on lxforums, asked a friend at hhp. posted this question on here. i just cant believe they don't stamp a date on the engine somewhere
Is your engine complete or you just have a block?
[Re: sixpackgut]
#934416
02/25/11 01:21 PM
02/25/11 01:21 PM
MattW
Ontario Canada
complete. but i still think if it was only a block there should be some way of telling a difference
Ok try this above the oil pan passenger side should be a bunch of numbers. Let me know.
