Page 3 of 13 1 2 3 4 5 12 13
Re: New 5.7 hemi eagle head [Re: MattW] #934337
02/22/11 05:34 PM
02/22/11 05:34 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yeah I figure they are catering to people with money.
I just read that the 392 is only going to be 1492 units, so maybe the 6.1 isn't dead.
I tried...
6.1 is still being installed in "normal" cars, so for now it's good, no worries.
Nice to hear you weren't hit with "international pricing" on the heads
Rich H.
Esse Quam Videri
Re: New 5.7 hemi eagle head [Re: brianw] #934338
02/22/11 05:35 PM
02/22/11 05:35 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
if you swap heads you will have a oil leak . the drain backs are in different positions from one side to the other . if you swap manifolds you should be able to drill and tap for the extra bolt holes
good info. thanks
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934339
02/22/11 06:19 PM
02/22/11 06:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
i just paid $494.
Ridiculously cheap
Rich H.
Esse Quam Videri
Re: New 5.7 hemi eagle head [Re: ZIPPY] #934340
02/22/11 06:38 PM
02/22/11 06:38 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I tried...
Yeah it called traveling across the border. Seriously I don't know how they sell stuff over here.?
Re: New 5.7 hemi eagle head [Re: MattW] #934341
02/22/11 06:44 PM
02/22/11 06:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Whatever works!
I'm not going to pretend to understand the pricing thing
Re: New 5.7 hemi eagle head [Re: ZIPPY] #934342
02/22/11 06:45 PM
02/22/11 06:45 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I forgot to mention what is the part # for the new Ali block I have P5153838 but it is coming up some type of suspension part.
Has anyone done any testing on it?
As for you trying thanks try a bigger hammer next time.lol
Re: New 5.7 hemi eagle head [Re: MattW] #934343
02/22/11 06:52 PM
02/22/11 06:52 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
So where is the cheapest place to get a 5.7 -> 392 forged rotating assembly.
that is what i want to know.....
someone has to know...
jm
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: New 5.7 hemi eagle head [Re: MattW] #934344
02/22/11 06:57 PM
02/22/11 06:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
p5155507 is the one I think most will want. It comes already bored to 4.125.
There are three other part numbers all with smaller bores.
Rich H.
Esse Quam Videri
Re: New 5.7 hemi eagle head [Re: ZIPPY] #934345
02/22/11 07:01 PM
02/22/11 07:01 PM
San Angelo, Texas
W8n2DustU Offline
W8n2DustU  Offline
San Angelo, Texas
So what is the price for the aluminum block? Who makes the aftermarket cranks? What is the rod journal size on a stock crank?
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: New 5.7 hemi eagle head [Re: wldtm] #934346
02/22/11 07:12 PM
02/22/11 07:12 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
ebay
Re: New 5.7 hemi eagle head [Re: ZIPPY] #934347
02/22/11 08:35 PM
02/22/11 08:35 PM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
You can bolt the eagles on an earlier 5.7 block as an upgrade, or no?
If you bought one of the 6.1 liter shortblocks you could bolt them on that and go, or?
Re: New 5.7 hemi eagle head [Re: W8n2DustU] #934348
02/22/11 08:42 PM
02/22/11 08:42 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Price for the block is 4000.00 to 4500.00 depending on which one you purchase.
For the crank you can get a 6.1 forged for around 400.00
I know Arrington is selling their cranks 4.25 for aroung 1000.00 this is a K1 but you can only buy it through them. Apparently BES bought theirs through them.
Re: New 5.7 hemi eagle head [Re: Bill_T] #934349
02/22/11 08:52 PM
02/22/11 08:52 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
yes you can. Think of it this way the 5.7 up to 2008 is like the 318 and the 6.1 is like the 360. you can swap them back and forth but you would have to open the intake port a bit for the increase size of the 6.1 intake.
The new 5.7 eagle is the same size as the 6.1 intake port size.
you can bolt on these heads and go.
as for bolting on these heads to a stock 5.7 I don't know if you would see any gain.
The stock 5.7 head work extremely well.
Once I receive my junkyard 5.7 I want to find this out.
One thing, the new head has a different exhaust port don't know if the stock logs will work.
Re: New 5.7 hemi eagle head [Re: ZIPPY] #934350
02/22/11 09:33 PM
02/22/11 09:33 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
ebay
i look. i never see them there. EVER!
need a link for proof
Re: New 5.7 hemi eagle head [Re: MattW] #934351
02/22/11 10:41 PM
02/22/11 10:41 PM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
yes you will see a gain, sons Magnum went from 14.15 stock to 11.99, Eagle heads & manifold 268 Comp Cam long tube headers, Eagle exhaust port opening is the same as 6.1
Re: New 5.7 hemi eagle head [Re: MattW] #934352
02/22/11 11:05 PM
02/22/11 11:05 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
shouldnt there be a nice increase in compression from the old to the new?
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934353
02/22/11 11:09 PM
02/22/11 11:09 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
stock head gaskets 04 - 08 engines about 9.5 to 1
09 heads on an 04-08 = 12:1 with stock gasket
with a .050 gasket is close to 11.5 to 1
dont quote me on exact numbers but these are close.
Re: New 5.7 hemi eagle head [Re: wldtm] #934354
02/22/11 11:19 PM
02/22/11 11:19 PM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
you probably would not want to use a stock gasket without adding a extra shim, a stock gasket with a shim will give about .040 piston to head clearance
Re: New 5.7 hemi eagle head [Re: mopardad] #934355
02/23/11 03:59 AM
02/23/11 03:59 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Why bother with 5.7L VCT stuff when a new bone stock 392 will run 10's in your racecar and get near 30MPG on the street??
If that motor will propel a 4100# Challenger to 12.29 and get 23MPG imagine what it'll do in a 3000# A-body....stock. Just add a predator or trinity tune and cheap bolt-ons and you are set. No BS.
Re: New 5.7 hemi eagle head [Re: SRT6776] #934356
02/23/11 09:51 AM
02/23/11 09:51 AM
NY usa
540challenger Offline
NY usa
It going to be a little while before the 6.4L b/c avaiable the hot ticket is the older 5.7 with the eagle head or the 6.1. As of righ now i pretty sure that there is no after market support for the vht controled motors which includes the 6.4L i sure this will change in a little amount of time but you got to wait.....
