Re: New 5.7 hemi eagle head
[Re: ZIPPY]
#934340
02/22/11 06:38 PM
02/22/11 06:38 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Yeah I figure they are catering to people with money. I just read that the 392 is only going to be 1492 units, so maybe the 6.1 isn't dead.
I tried...
6.1 is still being installed in "normal" cars, so for now it's good, no worries.
Nice to hear you weren't hit with "international pricing" on the heads
Yeah it called traveling across the border. Seriously I don't know how they sell stuff over here.?
[Re: MattW]
#934343
02/22/11 06:52 PM
02/22/11 06:52 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
So where is the cheapest place to get a 5.7 -> 392 forged rotating assembly.
that is what i want to know.....
someone has to know...
jm
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: ZIPPY]
#934345
02/22/11 07:01 PM
02/22/11 07:01 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
So what is the price for the aluminum block? Who makes the aftermarket cranks? What is the rod journal size on a stock crank?
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
[Re: wldtm]
#934346
02/22/11 07:12 PM
02/22/11 07:12 PM
Posts: 17,847 S.E. Michigan
ZIPPY
S.E. Michigan
ebay
[Re: Bill_T]
#934349
02/22/11 08:52 PM
02/22/11 08:52 PM
MattW
Ontario Canada
You can bolt the eagles on an earlier 5.7 block as an upgrade, or no?
If you bought one of the 6.1 liter shortblocks you could bolt them on that and go, or?
yes you can. Think of it this way the 5.7 up to 2008 is like the 318 and the 6.1 is like the 360. you can swap them back and forth but you would have to open the intake port a bit for the increase size of the 6.1 intake. The new 5.7 eagle is the same size as the 6.1 intake port size. you can bolt on these heads and go. as for bolting on these heads to a stock 5.7 I don't know if you would see any gain. The stock 5.7 head work extremely well. Once I receive my junkyard 5.7 I want to find this out. One thing, the new head has a different exhaust port don't know if the stock logs will work.
[Re: MattW]
#934351
02/22/11 10:41 PM
02/22/11 10:41 PM
Posts: 1,510 Manheim PA.
mopardad
Manheim PA.
yes you will see a gain, sons Magnum went from 14.15 stock to 11.99, Eagle heads & manifold 268 Comp Cam long tube headers, Eagle exhaust port opening is the same as 6.1
[Re: MattW]
#934352
02/22/11 11:05 PM
02/22/11 11:05 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
shouldnt there be a nice increase in compression from the old to the new?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#934353
02/22/11 11:09 PM
02/22/11 11:09 PM
wldtm
Dayton, Ohio
stock head gaskets 04 - 08 engines about 9.5 to 1
09 heads on an 04-08 = 12:1 with stock gasket
with a .050 gasket is close to 11.5 to 1
dont quote me on exact numbers but these are close.
PM for details
[Re: wldtm]
#934354
02/22/11 11:19 PM
02/22/11 11:19 PM
mopardad
Manheim PA.
you probably would not want to use a stock gasket without adding a extra shim, a stock gasket with a shim will give about .040 piston to head clearance
[Re: SRT6776]
#934356
02/23/11 09:51 AM
02/23/11 09:51 AM
Posts: 2,826 NY usa
540challenger
NY usa
Why bother with 5.7L VCT stuff when a new bone stock 392 will run 10's in your racecar and get near 30MPG on the street??
If that motor will propel a 4100# Challenger to 12.29 and get 23MPG imagine what it'll do in a 3000# A-body....stock. Just add a predator or trinity tune and cheap bolt-ons and you are set. No BS.
It going to be a little while before the 6.4L b/c avaiable the hot ticket is the older 5.7 with the eagle head or the 6.1. As of righ now i pretty sure that there is no after market support for the vht controled motors which includes the 6.4L i sure this will change in a little amount of time but you got to wait.....
