MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!!
#934100
02/21/11 09:42 PM
02/21/11 09:42 PM
Posts: 255 Washington, Pa
runner12
Washington, Pa
Re: MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!!
[Re: runner12]
#934101
02/21/11 09:48 PM
02/21/11 09:48 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
if you only move the trans a few inches you can see back there and findout.sorry for your problems. puff baby powder back there and it will stick to the oil and show a path.use a merror to see if you have to.
[Re: runner12]
#934102
02/21/11 09:50 PM
02/21/11 09:50 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
If you have narrowed it down to the back of the engine, then about all you can do at this point is to pull the engine or trans at this stage of the game and see whats up. 4 times on a rear seal, either everybody is doing something wrong or your looking in the wrong spot. Does it pour out just idleing or under load?
There are alot of things that people can be helped with over the internet, unfortunatly disassembling your car to diagnose it for you isn't one of them. If I had the choice, most times its easier to pull the trans IMO.
Outcast Dodge guy.
[Re: camastomcat]
#934115
02/21/11 11:30 PM
02/21/11 11:30 PM
blownzoom440
ELYRIA,OH
If it has oil pressure I don't think it has any oil plugs loose.
you might be suprised at how much of a leak you can have and still have fair psi.
[Re: blownzoom440]
#934117
02/21/11 11:34 PM
02/21/11 11:34 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Can't resally go along with that. Every time a plus was loose or oil was pouring out, never had more than 30 PSI and would not go up with RPM.
