Re: MAS. OIL LEAK, LAST TIME IM ASKING PLEASE HELP!!!
[Re: Cab_Burge]
#934122
02/22/11 12:25 AM
02/22/11 12:25 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
This sounds veery similar to an oil leak Scott and I fought with earlier this winter. We tried 4 difernt seals (different brands) and 3 different retainers (one being billet) and all leaked like what you are descirbing.
Our last hope before tearing it out and going through it was a rope seal. Thankfully that fixed it.
Good luck.
[Re: WILD BILL]
#934123
02/22/11 10:32 AM
02/22/11 10:32 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Good luck.
On your motor? A rope seal? I get no call ![](/ubbthreads/images/graemlins/shruggy.gif)
To the OP, If the rear seal has been replaced 4 times and still leaking then someone can't install a rear seal or the leak is elsewhere and that would be the cam plug in my estimation.
Take it to Bob George and have him help you out ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: runner12]
#934126
02/22/11 12:55 PM
02/22/11 12:55 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I m telling you i think you are on to somthing ..befor i stroked it it didnt leak a drop!! thanks Nick
What brand of crank?
Your problem might be the finish on the crank. Im thinking your crank might have a very defined knurl. Ive heard that if you emery cloth the knurl off that it helps with main seal leaks. Of course the best way would be to machine it off, but if its the car, Ive heard that emery cloth works pretty decent. Ive heard that the knurl finish will seal better with a rope seal??
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: B G Racing]
#934128
02/22/11 02:04 PM
02/22/11 02:04 PM
Posts: 99 USA
BB Dart 69
USA
Bring it by the shop and we will help pinpoint the problem.
Now theres a good Man I changed a main seal four times, had to put shim stock(30 thousands)then the main seal.
[Re: roadhazard]
#934130
02/22/11 05:20 PM
02/22/11 05:20 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Just a thought, you running main studs ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Also some billet retainers collect oil and do not drain back to the pan. This will overload the seals capabilities.
Good picture, I should have said main studs, thats what was causing my leak.
[Re: runner12]
#934132
02/22/11 08:29 PM
02/22/11 08:29 PM
roadhazard
Akron, Ohio U.S.A.
The problem is not the people installing the seal! Its somthing else. the motor did not leak in 440 form it started after the stroker was installed and it had a rubber seal in it befor. the crank is a mopar crank . I have not tried a rope seal yet,that is on the list . The way it leaks i find it hard to belive its the cam plug but hey at this point Ill belive any thing. THANKS. NICK
Are you using silicone on the seal? What type of retainer side seals? Is it a black Polyacrylate seal or a orange/brown Fluoroelastomer seal? What type of lube are you using? Are you sure the groove in the seal retainer cap is lined up with the groove in the block when it's torqued? Stock seal retainer or aftermarket and if so who's? Has the seal surface diameter been checked or compared to a stock crank?
4 seals in a row with a leak, something is not right. No reason a rubber seal can not work.
[Re: roadhazard]
#934133
02/22/11 10:22 PM
02/22/11 10:22 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
Back of the crank (torque converter hub area) drilled to far into an oil galley on the rear journal? Its rare, but I have heard of it happening over the years---and it is a new stroker crank......
Outcast Dodge guy.
[Re: roadhazard]
#934134
02/22/11 10:22 PM
02/22/11 10:22 PM
Posts: 255 Washington, Pa
runner12
Washington, Pa
Black ,seal orange hi temp, rubber side seals,with silocone, without ,old retainer , new billet one 440 source the way it came, they told me to mill it.010. I have never seen any thing like it! ![](/ubbthreads/images/graemlins/confused.gif) This is the kind of stuff that happens to me , I once had a tranny built and it would not work properly found out it was a 727 built for a european car? ![](/ubbthreads/images/graemlins/haha.gif)
[Re: roadhazard]
#934135
02/22/11 11:10 PM
02/22/11 11:10 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
I had this problem with main studs too, both stock and billet retainers. I used a dremel and a sanding drum until I had clearance.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#934137
02/23/11 12:00 AM
02/23/11 12:00 AM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
so what is it that you modified, any picts?
[Re: Quicksilver440]
#934138
02/23/11 12:21 AM
02/23/11 12:21 AM
Posts: 587 San Clemente, ca
enelson
mopar addict
mopar addict
San Clemente, ca
In my humble opinion...if you have a knurl...you need to run a rope seal. I've never had a problem with a rope seal on a knurled surface.
if I even think it's got a knurl I run a rope...
[Re: Deepockets]
#934139
02/23/11 10:17 AM
02/23/11 10:17 AM
roadhazard
Akron, Ohio U.S.A.
Ask and you shall receive ![](/ubbthreads/images/graemlins/biggrin.gif)
