Will a C body oil pan fit on a 69 Dart GTS w/ a 383? #933830
02/21/11 11:22 AM
02/21/11 11:22 AM
RI Deep in the rust belt
chargervert Offline OP
A friend of mine has a 69 Dart GTS 383 4 speed car. He was looking on E bay for an oil pan for a 383 A body. He found an ad for a 66-72 C body pan,and the seller was claiming it would fit big block A bodies too. Does anyone know if it will fit? If it will does he need the pickup tube for that pan,or will the one on his 383 now work? If not what will? I think he said that the C body pan had a 699 number on it. Also is there a different pan for 383 a bodies verses 440 a bodies? Any help from the A body experts would be great. thanks Pete
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Will a C body oil pan fit on a 69 Dart GTS w/ a 383? [Re: chargervert] #933831
02/21/11 11:41 AM
02/21/11 11:41 AM
the house on the left.
cogen80 Offline
cogen80  Offline
http://www.bigblockdart.com/techpages/tips.shtml
the 699 is a preferred one for a big block abody. i believe it has a notch cut out of it that clears the steering nicely.
Re: Will a C body oil pan fit on a 69 Dart GTS w/ a 383? [Re: chargervert] #933832
02/21/11 11:50 AM
02/21/11 11:50 AM
East Central Illinois
jeff57 Offline
jeff57  Offline
i think the 187 pan will also work. jeff57
Re: Will a C body oil pan fit on a 69 Dart GTS w/ a 383? [Re: jeff57] #933833
02/21/11 11:53 AM
02/21/11 11:53 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
187 does work also , the pickup tube for the 70 up hemi pan is available new and can be made to work with the 187 pan .
383 and 440's used the same pan in A bodies
Re: Will a C body oil pan fit on a 69 Dart GTS w/ a 383? [Re: JohnRR] #933834
02/21/11 11:55 AM
02/21/11 11:55 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
187 does work also
That's what I have on the 383 in my Duster - still had to give it a minor though.
Ride eternal, shiny and chrome
Re: Will a C body oil pan fit on a 69 Dart GTS w/ a 383? [Re: DirectSubjection] #933835
02/22/11 03:12 AM
02/22/11 03:12 AM
USA
big-block-dave Offline
USA
383/440 A-body, 893 OIL PAN go to this prior post.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
