SB LA TDC
#933699
02/21/11 01:38 AM
02/21/11 01:38 AM
Posts: 386 Maryland
reno340
Maryland
what is the easiest way to determine top dead center on a Mopar small block? (1972 340 w/ stock electronic distributor) Just researching in case I need a new cam?
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: SB LA TDC
[Re: MoparforLife]
#933701
02/21/11 09:33 PM
02/21/11 09:33 PM
Posts: 386 Maryland
reno340
Maryland
Are you talking about the mark at the harmonic balancer? If so, does it point to the 0 on the timing cover?
Re: SB LA TDC
[Re: RapidRobert]
#933703
02/21/11 10:31 PM
02/21/11 10:31 PM
Posts: 606 Montana
Yancy Derringer
Montana
put the slit on the dampener to the TDC zero mark on the timing tab AND the rotor is under #6 plug wire on the cap. This'll put the crank sprocket dot at 12 0'clock and the cam gear dot at 6 0'clock to match what you'll see in the pic & make for easy lining up the dots w a small steel scale
Nice try. If he's going to change the cam, it won't matter if the rotor is on no1 or no6, because once you take the cam drive and cam out, you'll be putting it BACK IN at no6, anyhow!!!
Look the BEST thing to do is actually CHECK your TDC while you are at it. Use a "piston stop" like this:
http://www.jerrybramlett.net/images/pic_installation.jpg
You can make, or buy them. Unhook the battery ground, get a wrench on the front crank bolt, and pull out no1 plug. Make sure the piston is down far enough that you can get the stop in. Gently rotate the engine clockwise until it stops. Make a temporary mark under TDC on the timing tab onto the dampener. Do the same counterclockwise.
This will leave you with TWO temporary marks. True TDC will be halfway between, and if the factory mark is correct, that is where it will be.
Google "cam degreeing" n such, to find out about "degreeing in" your cam. If you are gonna just throw it in there, then you
DO NOT REALLY NEED TO KNOW where TDC is, because the "marks" WILL ONLY LINE UP ONE WAY (Actually two)
That's with the crank sprocket (they are not gears) at 12 o clock and the cam sprocket at 6 o'clock---the way the "books" show. THIS SET UP no6 ready to fire NOT no1
The obvious second way is with the crank again at 12 o clock and the cam sprocket at 12 o clock --MUCH more difficult to view whether it's a "tooth off" or not. THIS SETS UP no1 ready to fire instead of 6
THE POINT IS, you don't actually need to set the engine on TDC before you tear it down --although probably easier--because when you install the new cam drive, you are FORCED to turn the crank until the mark on the sprocket lines up with the mark on the top sprocket.
I STRONGLY SUGGEST you invest yourself in some service / mechanics manuals, and do some Googleing. There are many many articles on installing camshafts
http://www.google.com/search?hl=en&s...mp;aql=&oq=
MANY of the camshaft manufacturers have 'tech' articles on their websites
Re: SB LA TDC
[Re: RapidRobert]
#933704
02/21/11 10:32 PM
02/21/11 10:32 PM
Posts: 386 Maryland
reno340
Maryland
ahhhhhhh, so when I put the distributor back in it will be at #6 plug wire. How will the oil pump shaft and gear be oriented?
