MITSU 3.0 REMAN HEADS #933689
02/21/11 01:10 AM
02/21/11 01:10 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Our Caravan's 3.o is starting to kill mosquitoes, so since it's still a nice van, I'd like to fix this.
Is there a good source of reman. heads or should I just have the originals fixed?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: MITSU 3.0 REMAN HEADS [Re: Magnumguy] #933690
02/21/11 01:23 AM
02/21/11 01:23 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Did you check out to see how much remans would be thru rock auto?
Re: MITSU 3.0 REMAN HEADS [Re: DaytonaTurbo] #933691
02/21/11 09:00 AM
02/21/11 09:00 AM
S.E.Ohio
S.E.Ohio
Never thought of them. I'll check.
Re: MITSU 3.0 REMAN HEADS [Re: Magnumguy] #933692
02/21/11 09:08 AM
02/21/11 09:08 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
they can be fixed without removing them if you really want.
chrysler made a tool to pull the guides up and then cut a ring for a snap ring to be installed without removing the heads
Re: MITSU 3.0 REMAN HEADS [Re: gtx6970] #933693
02/21/11 11:03 AM
02/21/11 11:03 AM
S.E.Ohio
S.E.Ohio
Cool, I'll check into that. My nephew works in an independant shop, he probably knows about this. Thanks
Re: MITSU 3.0 REMAN HEADS [Re: Magnumguy] #933694
02/23/11 01:33 PM
02/23/11 01:33 PM
S.E.Ohio
S.E.Ohio
Got a quote to do this for $1100, sounds high to me. Is it?
