Small Block Connecting Rod Side Clearance
#932385
02/19/11 03:55 PM
02/19/11 03:55 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I am assembling my small block stroker and measured the connecting Rod side clearance. The spec seems to be .009 to .017. Two are .014 the other two are .024, is this OK. Not sure what to do, should I try mixing up the rods? The crank is a MP stroker and the rods are Eagle H beams. All bought in 2001 so its too late to return anything. If swapping the rods around does not work im not sure what can be done to correct it.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
Re: Small Block Connecting Rod Side Clearance
[Re: stumpy]
#932388
02/19/11 06:22 PM
02/19/11 06:22 PM
finadk
East Brunswick, NJ
Thanks, after getting my head out of the book, i read the sheet that came with the rods and that said up to .025 so i am good.
Scott
1976 Corvette
