Re: 4 speed linkage
[Re: phil4161972]
#932329
02/19/11 04:20 PM
02/19/11 04:20 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
it woud help to know what exactly shifter you are using.
home of the Sox and Martin Hemi Duster
Re: 4 speed linkage
[Re: phil4161972]
#932331
02/19/11 04:45 PM
02/19/11 04:45 PM
Posts: 4,806 Moved to N.E. Tennessee
GomangoCuda
While it is true that the levers coming out the bottom of the E-body shifter tower have a very different offset from all other shifters it is not true that it is the only one that will fit. I have had Hurst Super Shifters and stock E-body rods in 2 e-bodies. They both fit perfect. Remember to use e-body shift levers on the transmission.
