Re: how to tell dana 60
[Re: ALKYW5DART]
#932322
02/19/11 04:21 PM
02/19/11 04:21 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
Car Dana 60 : 3" axletubes, Pinion snubber mount, Heavy, Insane price tag
Truck Dana 60: Most have larger and thicker axle tubes, No pinion snubber mount, Many have floating axles, real heavy, Scrap price - buy it by the pound
If you buy a truck 60 and have it cut it will be somewhat heavier than a car 60 because the center is thicker just about everywhere and the tubes are bigger and thicker. Brackets will need to be altered to fit larger tubes. If weight is an issue then get an aftermarket housing from Moser or Strange. DrDiff can set you up with what you need.
[Re: perfmachst]
#932324
02/19/11 06:49 PM
02/19/11 06:49 PM
Posts: 694 Michigan
Super Scamp
Buy a truck Dana same some $$, Buy a 1/2 ton or 3/4 ton. Watch out for the Heavy duty Dana's you don't want one of those units. They are marked with a HD60 on inside of the housing.
Just One Man's Opinion
Mopar Mafia Racing
[Re: Super Scamp]
#932325
02/19/11 10:34 PM
02/19/11 10:34 PM
Posts: 554 Kentucky
clovis
Kentucky
http://www.therangerstation.com/tech_library/Dana_BOM_numbers.htmlIf you want to e-mail me, I have the chart in an excel format that is somewhat sortable, as the chart gives Dana 44,60,61,70,80,fronts and rears. I have a tab on the sheet that narrows it down to just the 60-rears.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
