Roadrunner rear window ribbon sealer/ gasket #931830
02/18/11 03:45 PM
02/18/11 03:45 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
I know this came up before but I cant remember the conclusion.
Does it need 5/16 or 3/8 thick window ribbon?
I think some previously said to try both and see which one works best, but that doesnt see practical..
HELP !
Thanks,
Re: Roadrunner rear window ribbon sealer/ gasket [Re: sthemi] #931831
02/18/11 04:17 PM
02/18/11 04:17 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I just used the 5/16th's stuff on my 68 GTX.....mouldings etc all OK
Re: Roadrunner rear window ribbon sealer/ gasket [Re: superwrench] #931832
02/18/11 04:40 PM
02/18/11 04:40 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
5/16ths
I try to make sure I do not stretch or flatten the butyl strip when I lay it down to ensure uniform contact when laying the glass. That way your seal occurs as the glass comes into contact with the seal. This helps eliminate initial voids and excess working of the glass to meet the butyl strip.
Re: Roadrunner rear window ribbon sealer/ gasket [Re: 70mopes] #931833
02/19/11 12:27 AM
02/19/11 12:27 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks for the response !
I will pick up a roll tomorrow.
Re: Roadrunner rear window ribbon sealer/ gasket [Re: sthemi] #931834
02/19/11 01:52 AM
02/19/11 01:52 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I agree also...5/16".
