Re: 727 - Converter Stall keeps to high, why?
[Re: 6o4o]
#931561
02/18/11 02:42 PM
02/18/11 02:42 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
what if the valvebody sends not enough oil to the converter like it happens in P? I would guess stall would also get higher / more slip?
By the way, it's an AUTOMATIC shift TF-2, no manual valve body...
If it has a TF 2 it should have came wit ha new manual valve to remedy that, it's not a pressure thing , it's the convertor , where did you get it from ?
[Re: forphorty]
#931567
02/19/11 04:07 PM
02/19/11 04:07 PM
Posts: 2,273 Bern, Switzerland
6o4o
Bern, Switzerland
You can build a 9.5" tighter than an 11"! I had 9.5" that stall at 2000RPM, it all depends what the converter maker makes out of it! The 9.5" ist just the much better piece than a 11" stock converter... But anyway, not discussing the size of the converter So the conclusion is, the converter is the problem, not the trans/valvebody?
