Indy Horsepower ! #931477
02/18/11 02:52 AM
02/18/11 02:52 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
HI guys !
Putting my combo together and get a lt of comments from it, but never from people who know what they are talking about, so I'm turning to you.
Here is what I have:
408 cid
360-1 heads 210cc int runner version
race port
10.9:1 cr 190lbs cranking pressure
HUghes engines cam 252/256* dur @ 50
626 lift
Indy Intake 800 cfm Holey
904 trans, 3800 stall, low gearset
3.91 rear gear on 35 spline spool
28x9 ET drag slicks
In a 67 Barracuda 3300 lbs
elec water pump, manual steering
what would me my Et's ? HP ?
Trying to clear up all the [Edited by Moparts - Family Friendly Site - Keep it clean] coming to me and get reliable comments...
Dan
Re: Indy Horsepower ! [Re: Wedgeman] #931478
02/18/11 03:33 AM
02/18/11 03:33 AM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
10.50
Re: Indy Horsepower ! [Re: cbarracuda] #931479
02/18/11 07:20 AM
02/18/11 07:20 AM
Q
Quicktree Offline
Quicktree  Offline
Q
kind of mis-matched combo, but it should make some power. needs more converter/gear and with a 9" slick you better have a well sorted out suspension.or be able to control the power down low. ET guess somewhere in the 10s if it hooks
Re: Indy Horsepower ! [Re: Wedgeman] #931480
02/18/11 08:49 AM
02/18/11 08:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
10.7 - 10.8... if all goes good... I'm assuming this
is a track car... I'm curious why that duration...
seems short for a 408(strokers like duration) and
they like carb
Re: Indy Horsepower ! [Re: MR_P_BODY] #931481
02/18/11 10:05 AM
02/18/11 10:05 AM
Out West
408strokerdart Offline
Out West
they like carb
Was thinking the same thing about both the cam and carb. Duration looks at least 10 degrees to short and it would love a 950 carb.
Re: Indy Horsepower ! [Re: 408strokerdart] #931482
02/18/11 12:16 PM
02/18/11 12:16 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
my combo was very simular to yours at one time,accept i had a 4.10 with 727 and ran 11.30@122.
Re: Indy Horsepower ! [Re: mopar dave] #931483
02/18/11 12:45 PM
02/18/11 12:45 PM
Nevada
theman440 Offline
theman440  Offline
Nevada
11.20's tell us how it comes out.
Re: Indy Horsepower ! [Re: theman440] #931484
02/18/11 01:12 PM
02/18/11 01:12 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
my 60's were 1.6 at the time.
Re: Indy Horsepower ! [Re: Wedgeman] #931485
02/18/11 01:30 PM
02/18/11 01:30 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Guys, notice he is running only a 28" tire so he isn't too far off on gearing and converter.
When I had a home ported stock headed 408, .540 flat solid, 950hp carb, 4.56 gear, 30" tire, 4000 stall, 3500 lbs, I went 11.20 at 119.
He should be all over 10.7's.
But, with a little more gear and converter, easy mid 10's.
Re: Indy Horsepower ! [Re: TheOtherDodge] #931486
02/18/11 09:05 PM
02/18/11 09:05 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Thanks for all your input guys.
First, I wanted to choose that cam because I did not want to let too much pressure out, and stay around 185 cranking pressure
Second, remember that I run a 904 with a low gearset, wich make a 3.91:1 act like a 4.30!
You think it would be wrong to keep my 28'' slicks ?
What would you change?
Dan
Re: Indy Horsepower ! [Re: Wedgeman] #931487
02/18/11 09:11 PM
02/18/11 09:11 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I agree, I will look very closely at a bigger carb
Dan
Re: Indy Horsepower ! [Re: Wedgeman] #931488
02/18/11 09:15 PM
02/18/11 09:15 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
I think with the right converter, trans and gear that the combo should be good for low 10s. My brothers car sounds quite similar to what you are explaning and it goes 10.50s @ 125 with a 28X9 Hoosier slick. You heads are bigger, cam seems more aggressive and the cubes are more than ours...I think you will go faster than 10.50s.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Indy Horsepower ! [Re: PUNK] #931489
02/18/11 09:43 PM
02/18/11 09:43 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I figured between 535 and 550 HP. Should go 129 MPH+ @ 3300 lbs.
Re: Indy Horsepower ! [Re: cbarracuda] #931490
02/18/11 10:09 PM
02/18/11 10:09 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
maybe a 30 or 40 car is heavy
Re: Indy Horsepower ! [Re: Wedgeman] #931491
02/19/11 12:15 AM
02/19/11 12:15 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
You would have been better off changing the rear gear instead of the low gearset. A drag race engine doesn't like the big rpm drop on the gear change. Make sure you get a good converter.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Indy Horsepower ! [Re: bigtimeauto] #931492
02/19/11 01:50 PM
02/19/11 01:50 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I will looks closely at that too,
Dan
Re: Indy Horsepower ! [Re: bigtimeauto] #931493
02/19/11 02:21 PM
02/19/11 02:21 PM
Mabe a all out high RPM special drag motor doesn't like big RPM drops in the higher gears changes like the 3 to 4 gear and 4 to 5th gear changes but most of the low HP(under 600 HP)automatic cars I know love the low gear sets on small tires
Re: Indy Horsepower ! [Re: Cab_Burge] #931494
02/19/11 05:33 PM
02/19/11 05:33 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I dont see this combo being too far off.
Its deffenitly not perfect but....
I would say 10.5 when sorted out.
Re: Indy Horsepower ! [Re: Cab_Burge] #931495
02/19/11 08:29 PM
02/19/11 08:29 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
A lower horsepower engine will love the lower first gear but hate the gear change drop and the long high gear pull where the more rear gear will make the engine happier all across the board.
Re: Indy Horsepower ! [Re: sshemi] #931496
02/19/11 08:38 PM
02/19/11 08:38 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I think the combos pretty good except for the stall. It could be higher IMO, more like 4500 to 4800. The gearing is fine, those 9 x 28 MT ,ET tires are actually 27.3" With the 3.91, thats actually the same gearing as a 4.56 gear and 32" tire.
With that 3800 stall and 3300# Im guessing 11.0s to 11.20,s
