1970 Challenger master cylinder #931404
02/18/11 12:19 AM
02/18/11 12:19 AM
Canada
sam c Offline OP
sam c  Offline OP
Canada
Hello I need to pick up a disc brake master cylinder and would like to know which one would look the closest to original for a 1970 Challenger.I am not building an OE car so casting numbers are not important Thanks in advance
Re: 1970 Challenger master cylinder [Re: sam c] #931405
02/18/11 12:41 AM
02/18/11 12:41 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
You can choose between a '69-'70 disc brake C body master cylinder which has a 1-1/8" bore, or a '71-75 Mopar disc brake master cylinder that has a 1-1/32" bore. Either works fine. Paint the entire assembly black and it looks fairly correct.
Re: 1970 Challenger master cylinder [Re: Mastershake340] #931406
02/18/11 12:44 AM
02/18/11 12:44 AM
Canada
sam c Offline OP
sam c  Offline OP
Canada
Thanks I will check them out
