Stock or 1" rear Leaf Spring? #931366
02/17/11 11:02 PM
02/17/11 11:02 PM
NY
old340dog Offline OP
NY
I,m going to be ordering new rear leaf springs from ESPO Spring and Things shortly. I'm having a hard time on deciding on to order stock replacement spirngs or ones with a 1 lift. My springs on my 73 duster 340 are the original ones, the front rubber bushings are bad. And the leafs themselves are looking pretty flat. So it is hard to imagine what the height would be good.
I'm afraid with a 1" lift the rear will sit to high. I don't want the rear really sitting high like I have air shocks maxed out.But wonder if the stock springs will make the car sit no higher than it does now.
Any thoughts, pictures or advantages of one over the another?
I might ad that I'm running 15" 60 series tires on the rear and 14" 70 series tires on the front.When I bought the tires I made sure the tire diameters where almost the same. They only vary by.5 inch.
thanks,
old340dog
Re: Stock or 1" rear Leaf Spring? [Re: old340dog] #931367
02/17/11 11:09 PM
02/17/11 11:09 PM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
When I bought a set for my 71 Road Runner, I got the stock ones and they sit very high. I know a lot of guys go for the 1" higher ones. You should probably see what the A-body guys are doing.
Re: Stock or 1" rear Leaf Spring? [Re: sixpack4spd] #931368
02/17/11 11:10 PM
02/17/11 11:10 PM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
My buddies 70 Super Bee has the same springs and his car sits too high in the back too...
Re: Stock or 1" rear Leaf Spring? [Re: old340dog] #931369
02/17/11 11:11 PM
02/17/11 11:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd go stock...
Re: Stock or 1" rear Leaf Spring? [Re: Challenger 1] #931370
02/17/11 11:57 PM
02/17/11 11:57 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i went with 1" over on my 70 rr,it sat high during restoration,but once everything was back in it sits just right
Re: Stock or 1" rear Leaf Spring? [Re: meepmeep70] #931371
02/18/11 12:06 AM
02/18/11 12:06 AM
BDW Offline
BDW  Offline
Another vote for stock, I got +1 and it sat too high.
Re: Stock or 1" rear Leaf Spring? [Re: old340dog] #931372
02/18/11 01:07 AM
02/18/11 01:07 AM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I bought stock height and ended up ordering 2" over stock springs. The stock were ok and then settled to look like it was sagging over a few months. My 2" over springs settled down nicely without that high rear end look.
Re: Stock or 1" rear Leaf Spring? [Re: sixpack4spd] #931373
02/18/11 01:18 AM
02/18/11 01:18 AM
At a gas station near you
badblack68 Offline
badblack68  Offline
I have the ESPO Hemi style springs that are 1" over stock. The springs have settled in nicely and I think the ride height is just right.
Re: Stock or 1" rear Leaf Spring? [Re: badblack68] #931374
02/18/11 01:21 AM
02/18/11 01:21 AM
badblack68 Offline
badblack68  Offline
This pic is after one year and a few thousand miles.
Re: Stock or 1" rear Leaf Spring? [Re: old340dog] #931375
02/18/11 02:29 AM
02/18/11 02:29 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Go with the 1" over ESPO springs and you'll be happy.
I used them on both my Dusters and they give the perfect stance.
They will settle some after awhile too. Sorry no pics till I get home-out of town.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Stock or 1" rear Leaf Spring? [Re: MY340] #931376
02/18/11 02:35 AM
02/18/11 02:35 AM
Lyons, CO
MileHighDart Offline
Lyons, CO
I also did the +1 inch springs from espo on my dart.
Seemed maybe a little high at first but they have settled a little. I think its just right now.
Re: Stock or 1" rear Leaf Spring? [Re: MileHighDart] #931377
02/18/11 10:04 AM
02/18/11 10:04 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
When I ordered these from Detroit Spring, I knew I would not be running the 70's on the back, but 60's. I ordered 1 inch over and I think it gives it a nice rake. These are also the 7 on one side six on the other HEMI springs. I'm not convinced that a Dart should get the 1 inch. You have low fenders to begin with.
Re: Stock or 1" rear Leaf Spring? [Re: DANA60] #931378
02/18/11 10:06 AM
02/18/11 10:06 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Here's my Dart. This is with an Alterkation and 17's, so it will sit a little different. I tried to keep it even accoss the body.
Re: Stock or 1" rear Leaf Spring? [Re: MY340] #931379
02/18/11 10:44 AM
02/18/11 10:44 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
pic
Re: Stock or 1" rear Leaf Spring? [Re: old340dog] #931380
02/18/11 11:26 AM
02/18/11 11:26 AM
CT
3
340KID Offline
340KID  Offline
CT
I just ordered espo +2 for my son's Duster, they should be here today actually, decided to go with +2's - if it's to high you can always block the rear a little, you can't go the other way if it's too low.
Re: Stock or 1" rear Leaf Spring? [Re: 340KID] #931381
02/18/11 07:35 PM
02/18/11 07:35 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
here are espo +1" on jamies dart. it looks good with the 14" wheels on it. i put my 17" wheels on the car and i think it would have looked better with stock height springs on it.. it really depends what wheels and the look your going for..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Stock or 1" rear Leaf Spring? [Re: abodyjoe] #931382
02/18/11 08:10 PM
02/18/11 08:10 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Here is my 76 with ESPO +1 and 14" wheels.
Re: Stock or 1" rear Leaf Spring? [Re: old340dog] #931383
02/19/11 09:37 PM
02/19/11 09:37 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
pic after installed
Re: Stock or 1" rear Leaf Spring? [Re: MY340] #931384
02/19/11 09:44 PM
02/19/11 09:44 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
old Duster with 1" over
Re: Stock or 1" rear Leaf Spring? [Re: MY340] #931385
02/19/11 11:19 PM
02/19/11 11:19 PM
tx
craigsmytcudas Offline
tx
I have +1 springs on a cuda as seen on my web site cover page, i expect to see a slight drop when I get it out this spring very happy camper .
