Page 2 of 3 1 2 3
Re: Please, please help with vibration problem [Re: 451Mopar] #931061
02/20/11 02:27 PM
02/20/11 02:27 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
If the flexplate has a large notch missing on outer edge(Not being perfect circle), then there is supposed to be NO WEIGHT on converter.
x2
The thing is, it is neither. It is a four leaf clover shape. Not a perfect circle, and not a half moon cut out.
Re: Please, please help with vibration problem [Re: larrymopar360] #931062
02/21/11 02:41 PM
02/21/11 02:41 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
wrong flex plate. The flexplate i used on my 360/380 crate motor was like the bottom one shown in the pic that jbc426 posted; round with a big scallop taken out, I think it was a Mr. Gasket piece though, and no weights on the converter.
Re: Please, please help with vibration problem [Re: pauly v.100] #931063
02/21/11 03:14 PM
02/21/11 03:14 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Ok, that is my plan. Remove weight from converter and use scalloped flexplate. Thanks!
Facts are stubborn things.
Re: Please, please help with vibration problem [Re: pauly v.100] #931064
02/21/11 03:19 PM
02/21/11 03:19 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Sometimes in this hobby, you have to take two steps backwards to be able to take another step forward. It goes with the territory and makes final victory that much sweeter!I know we all go through our struggles in the quest to enjoy old Mopars.
The pics are straight out of the Summit on-line catalog. Let us know how it works out.
Re: Please, please help with vibration problem [Re: larrymopar360] #931065
03/10/11 05:25 PM
03/10/11 05:25 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
What next???? Mechanic replaced flexplate with BM "scalloped" flexplate and removed the weight from the converter, but no change! Even parked, in Park or Nuetral, has soon as rpm's are brought up to about 2K, it vibrates badly.The hardest thing to figure is it did the exact same thing with the old 318/904 combination.Everything other than accessories are new.I disconnected all the belts and it still shakes at 2K.I really don't know what to do next.Out of money and patience.Right now I have an $8000 boat anchor that I can't drive without getting very annoyed and frustrated.
Re: Please, please help with vibration problem [Re: larrymopar360] #931066
03/10/11 05:36 PM
03/10/11 05:36 PM
scratchnfotraction Offline
check to make sure the front damper has not sliped on the rubber and is off balance
make sure its for a 360 also
either you have a mechanical failure/problem or its mixed on the balanced parts is my guess
Re: Please, please help with vibration problem [Re: scratchnfotraction] #931067
03/10/11 06:14 PM
03/10/11 06:14 PM
California
Hotlumpy Offline
Hotlumpy  Offline
California
I had a problem like that and one of the gentleman on this web site told me to check my bellhousing bolts. They were loose, tightened them and problem solved. seems like too easy of a fix, but it's easy to try!
Re: Please, please help with vibration problem [Re: Hotlumpy] #931068
03/10/11 06:20 PM
03/10/11 06:20 PM
California
Hotlumpy Offline
Hotlumpy  Offline
California
Also, check your timing, and check voltage to the coil. I had a bad ballast resistor once that cut power to the coil down to 3.5 volts and my car shook violently. Timing could do it too, set it around 12 initial and see how she runs.
Re: Please, please help with vibration problem [Re: Hotlumpy] #931069
03/10/11 06:43 PM
03/10/11 06:43 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
For further peace of mind and process of
elimination, check your mounts on both the tranny and engine besides the bellhousing bolts.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Please, please help with vibration problem [Re: HYPER8oSoNic] #931070
03/10/11 11:46 PM
03/10/11 11:46 PM
West Virginia
N
NewbombTurkk Offline
N
West Virginia
he says it did the same thing with the old 318/904.....so it is NOT a new 360 problem right?
1969 Buick Sportwagon 455 Stage 1 Ram Air SOLD
Nationwise Auto Parts Alumni 1982-1984
Now 1972 El Camino, original 402
Re: Please, please help with vibration problem [Re: NewbombTurkk] #931071
03/11/11 02:25 AM
03/11/11 02:25 AM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
If you had the same issue with the old motor/trans combo, then take a look at things that have remained in the driveline..same trans mount, balancer, pulleys, I know some of those things don't swap over to what you have now but of those things that do, have a look. Make sure Distributor shaft isn't bent, giving you erratic fire out f the cap.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Please, please help with vibration problem [Re: NewbombTurkk] #931072
03/11/11 02:53 AM
03/11/11 02:53 AM
montreal, quebec,canada
7e5dartsport Offline
i would double-check the damper. it should look different than 318/340 dampers wich are neutrally ballanced. otherwise , did you use the same tranny as with the 318? it could be the trans internally or the torque(318) has the hub partially broken (i have seen it before in 904s).could it be your 318 did have the hub broken and then you installed the new torque with the broken piece still laying inside the trans ??? it would do exactly as described plus some noise coming from the trans probably... check the 318 torque hub just to make sure it wasnt broken
fully legal sounds the same as full illegal...
Re: Please, please help with vibration problem [Re: 7e5dartsport] #931073
03/11/11 08:04 AM
03/11/11 08:04 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
i dont have money to have other people pull and repull my trannys.but that is beside the point,you either have the wrong damper or something is wrong in the engine.if you had all the acc.off and it still vibrates with correct vert and plate,thats all it can be
Re: Please, please help with vibration problem [Re: mcmopars] #931074
03/11/11 03:25 PM
03/11/11 03:25 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Everything is new, including trans, electronic ignition, etc.Damper is one that came with the Mopar Performance motor.I guess that would be the easiest thing to replace right now, but I really don't think they built this with the wrong component.It is not any accessories because I already removed all the belts and it still vibrates. I will try a different ballast resistor, as suggested, what the heck, it is easiest enough. Everything else is new, including coil. It is so baffling, because it did this with the old motor, trans, converter, etc.
Re: Please, please help with vibration problem [Re: larrymopar360] #931075
03/11/11 06:34 PM
03/11/11 06:34 PM
check the timing then
i have seen them so far advanced it souded like it had a choppy cam in it
way over advanced will shake and ping under med load
if its a mag engine and your mixing the la stuff with it it could be off on the balance
maybe its a premag bottom end and you have added magnum balance stuff
but then again i dodnt see how the other engine did this also
very interesting in deed
Re: Please, please help with vibration problem [Re: scratchnfotraction] #931076
03/11/11 08:03 PM
03/11/11 08:03 PM
what if the choke wasnt opening . engine would run very rough as it gets hot ??? also, there may be more than one weigth on the converter , you guys removed only one ??? good luck
Re: Please, please help with vibration problem [Re: 7e5dartsport] #931077
03/11/11 08:43 PM
03/11/11 08:43 PM
also i would check the firing order because cylinders number 5 and 7 are too easy to mix-up. on another note, one cylinder may not be firing. to check it: with the engine running remove the wire from the spark plug and slowly take the wire away from the plug. you should hear it ignite and as you take the wire away the engine will sligthly slow down, if everything is fine with that cylinder. if the engine doesnt slow down, there is something wrong with that cylinder. put the wire back on the plug and repeat for all cylinders. there are special pliers to do this so you dont get shocked from the ignition.
Re: Please, please help with vibration problem [Re: 7e5dartsport] #931078
03/12/11 12:36 AM
03/12/11 12:36 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
They are easy to mix up, I've done it,but they are correct now.This vibration is not constant, like when there is a bad plug wire. It is harmonic in nature, most noticable at about 45 mph, but also while parked in N or P, once the rpm are brought up to about 2000.Today I removed the poly trans mount and installed a OEM one.Helped alot, but still noticable harmonic vibration around 45mph.I have heard from a couple others who have installed these and have no problems.I had the poly one on my old motor and trans, and same deal, so I removed it and put on OEM one.Is the rubber mount just masking a problem? Again, what baffles me most is that I had the same issue with old motor, trans, torque converter set up.Exactly the same.
Re: Please, please help with vibration problem [Re: scratchnfotraction] #931079
03/12/11 12:42 AM
03/12/11 12:42 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
It idles nice and smooth, and timing is set pretty middle of the road right now.It doesn't misfire, hesitate, or ping.It just vibrates when on the gas at around 35mph and a little worse around 45mph, but smoothes when you speed up or slow down.No LA parts where mixed with this motor.It is a Mopar Performance 360, with all new parts and complete.I just added viscous fan, carb, headers, and fuel pump. I did remove all the belts for just a minute to see if it was one of the accessories, but it still vibrated.Removing the poly trans mount helped alot, but still some harmonic vibration.Thx.
Re: Please, please help with vibration problem [Re: larrymopar360] #931080
03/12/11 12:45 AM
03/12/11 12:45 AM
yeah me too & we're gonna laugh when we find it. & no excessive voltage drops/probs/ in the ign1 (run) circuit/components. What is related between the 2 engines?? EDIT to b clear they both vibrated in neutral parked in your driveway right?
Page 2 of 3 1 2 3
