Trans Question, flex plate? #931019
02/17/11 11:38 AM
02/17/11 11:38 AM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline OP
Which flex plate should go with the 904? the small one or the big one?
Re: Trans Question, flex plate? [Re: 268RTs4ME] #931020
02/17/11 11:42 AM
02/17/11 11:42 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I think it's the smaller of the 2 , do you have the convertor ?
Re: Trans Question, flex plate? [Re: JohnRR] #931021
02/17/11 11:46 AM
02/17/11 11:46 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Definitely the smaller one.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Trans Question, flex plate? [Re: Prodart440] #931022
02/17/11 12:02 PM
02/17/11 12:02 PM
2
Thanks for info.
Re: Trans Question, flex plate? [Re: Prodart440] #931023
02/17/11 01:59 PM
02/17/11 01:59 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You DO know that the 727 was available with different sized flexplates, right?
The LOW stall versions were huge, to accomodate the larger converter. The factory high stalls that I have seen use the smaller plate.
In this case though, I would lean toward using the smaller one. Compare the plate to the pattern on the converter to make sure that the 4 mounting bolts line up.
Re: Trans Question, flex plate? [Re: Kern Dog] #931024
02/17/11 02:54 PM
02/17/11 02:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Also most after market converters use the small plates.
