Re: 413 cam shaft gears.?????????????? [Re: IcorkSOAK] #930441
02/18/11 08:29 PM
02/18/11 08:29 PM
Tracy, CA, USA, Earth
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
I still want to see a picture!
Re: 413 cam shaft gears.?????????????? [Re: rabid scott] #930442
02/18/11 09:24 PM
02/18/11 09:24 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
I thought I had a pic ....
They are really a useLESS piece .... no one makes cams for them PLUS the cam-tech way-back-when is junk anyways.
If someone has a MH service manual .. there is a pic or two in there.
Re: 413 cam shaft gears.?????????????? [Re: IcorkSOAK] #930443
02/18/11 09:29 PM
02/18/11 09:29 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
HERE is one ....
Re: 413 cam shaft gears.?????????????? [Re: IcorkSOAK] #930444
02/18/11 09:46 PM
02/18/11 09:46 PM
Newfoundland
mopar_man Offline OP
Newfoundland
Thanks Doc , same pic as i have without the paint . So the cam spins in reverse
Re: 413 cam shaft gears.?????????????? [Re: mopar_man] #930445
02/18/11 09:49 PM
02/18/11 09:49 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
mm ... yes the cam spins in R ... but the gear on the cam is diff ....and so is the intermediate shaft gearing ....so it will spin the distributor and the oil-pump correctly.
Re: 413 cam shaft gears.?????????????? [Re: IcorkSOAK] #930446
02/18/11 11:25 PM
02/18/11 11:25 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
we had two 400 Chrysler engines in my dads boat. when we replaced them we got two short-blocks from machandles with two new 452 heads. we swapped the steel cranks (one clockwise,on cc) they both had gears and chains, the gear on the cam was different in each engine, was like a mirror image, lobes too,dist turned same on both,18436572-12756348. That a late model industrial motor, got different heads right.
